查看: 385|回复: 16
Endorsement
 楼主| 发表于 2020-4-4 11:33:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"I want to know is it worth getting your Endorsement to get a higher paying job. I am studying to get my  Tank, Hazmat and double and triple endorsements. I need some feedback with drivers that has there endorsement already please thanks","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-4 14:37:39 来自手机 | 显示全部楼层
933783 发表于 2020-04-04 05:07:15 cool and thank you so much
","text":"To get your hazmat the first step is getting your fingerprints and background check done. Once you pass that then you do your written test. You may be able to haul freight you can’t now. But does it pay more? Not usually if you’re a company driver. If you have your own authority? The insurance cost increases drastically to haul hazmat. Many truly independents don’t mess with it. \n\nDoubles and triples.... That’s a nightmare all its own. Unless you’re going to drive for a union company such as ABF or similar I don’t think it’s worth it. I have my endorsement and have for 30 years. I’ve pulled double about 15 times is all. Way more work breaking them apart. Way more work pulling them in the winter if you’re where it snows. Now if it gets you a dedicated run that has you home often it may be worth it. That’s another one of those personal decisions. ","replyToPid":351649}
发表于 2020-4-4 12:35:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"hazmat and doubles depend on the carrier you plan on working for...I would get your tanker endorsement no matter where you go because even if you end up pulling a box if you get liquid totes over a certain amount it requires tanker endorsement","replyToPid":0}
发表于 2020-4-29 09:41:58 来自手机 | 显示全部楼层
945420 发表于 2020-04-04 03:42:57 it's all easy and it's good just in case, you don't even need to study. take the test first time, if you fail, they give you the answers, study the answers and retake, only four questions change.
","text":"I feel so much safer on the road after reading this.","replyToPid":351641}
发表于 2020-4-6 08:15:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I got the doubles/triples and hazmat endorsements when I got my CDL back in '93, figuring versatility.   I never pulled doubles until I started pulling double tanks in the North Dakota oilfield 20 years later hauling water.  By then, I had dropped hazmat since I spent ten years on a civilian contractor transportation contract at Ft. Campbell and the company didn't pay extra for hazmat holders or cover the background checks.   We didn't require it on post, so it simply didn't make sense.  I obtained the tank endorsement a couple of years prior to moving to North Dakota while hauling bulk def and oil at a regional job out of Nashville.   If the position you're looking at is worthwhile, get the endorsement(s) and add the experience,  if nothing else.  It just gives you more versatile options in the future, in my opinion.   The tests aren't that bad and any place that hires you for something requiring an endorsement is going to add their training anyway.  One should never stop learning,  no matter how many years out here.  Go for it and good luck.  Be safe...","replyToPid":0}
发表于 2020-4-4 18:26:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always get every endorsement on the CDL. It’ll expand your opportunities for better paying driving jobs. Both test are easy to pass. Got my hazmat got a job in the oilfields and been making bank since. ","replyToPid":0}
 楼主| 发表于 2020-4-4 11:45:12 来自手机 | 显示全部楼层
","text":"cool and thanks will do","replyToPid":351641}
发表于 2020-4-4 11:37:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"tanker, and doubles/ triples are pretty easy one time tests.  I have them just in case. I can't really speak to the hazmat,  but i think that takes investing some time","replyToPid":0}
 楼主| 发表于 2020-4-4 11:42:21 来自手机 | 显示全部楼层
929659 发表于 2020-04-04 03:37:30 tanker, and doubles/ triples are pretty easy one time tests.  I have them just in case. I can't really speak to the hazmat,  but i think that takes investing some time
","text":"a company wants to hire me now but I have to get my tanker endorsement. I will stop OTR and find a local driving job.","replyToPid":351639}
发表于 2020-4-4 11:42:57 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"it's all easy and it's good just in case, you don't even need to study. take the test first time, if you fail, they give you the answers, study the answers and retake, only four questions change."}
 楼主| 发表于 2020-4-4 13:07:15 来自手机 | 显示全部楼层
837569 发表于 2020-04-04 04:35:23 hazmat and doubles depend on the carrier you plan on working for...I would get your tanker endorsement no matter where you go because even if you end up pulling a box if you get liquid totes over a certain amount it requires tanker endorsement
","text":"cool and thank you so much","replyToPid":351648}
发表于 2020-4-4 23:01:22 来自手机 | 显示全部楼层
GMT+8, 2026-4-18 06:36 , Processed in 0.144013 second(s), 24 queries .
