查看: 132|回复: 4
Got a weight scale ticket for excess of 1200 pounds
 楼主| 发表于 2020-4-3 08:07:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"Got a weight scale ticket at Arizona for 1200 pounds more weight..Is there any way I can fight this ticket please guys  if you can suggest please if I should go to trail or not to fight this please...Thanks ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-3 22:12:42 来自手机 | 显示全部楼层
{"replyToPid":351130,"replyTo":"
107346 发表于 2020-04-03 00:48:35 if you have a cat scale prior the ticket. call cat scale and talk to them with your fuel receipts!
","text":"Did you scale out? If you were over 1200 lbs the ticket is yours. Unless you scaled it at a cat scale beforehand "}
 楼主| 发表于 2020-4-3 10:16:45 来自手机 | 显示全部楼层
","text":"Thanks for the advice bro...🙏","replyToPid":351130}
发表于 2020-4-3 08:22:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I am very surprised that they gave you a ticket I thought scales was looking the other way for the ones that are open. ","replyToPid":0}
发表于 2020-4-3 08:48:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you have a cat scale prior the ticket. call cat scale and talk to them with your fuel receipts!","replyToPid":0}
GMT+8, 2026-2-12 11:04 , Processed in 0.086254 second(s), 24 queries .
