查看: 564|回复: 19
Weight scale ticket for 1200 pounds more weight
 楼主| 发表于 2020-4-3 08:03:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"Got a weight scale ticket at Arizona for 1200 pounds more weight..Is there any way I can fight this ticket please guys I need help if anybody can suggest anything please..Thanks ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-3 09:07:49 来自手机 | 显示全部楼层
625878 发表于 2020-04-03 00:59:25 I would hire a professional right away, plus why would you haul 1200 pounds over gross.\n\nThere isn’t a shipper out there that will give two 💩‘s about the fine you are about to receive
","text":"He needs to hire a professional driver to drive his rig for him 😂😂😂","replyToPid":351132}
回复 支持 9 反对 0
发表于 2020-4-3 16:09:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do not hire a professional.\nThat's a 100$ ticket.\nPay it. Learn from this mistake.","replyToPid":0}
发表于 2020-4-3 10:48:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Even though u should always go to a CAT scale when in doubt about your weights, there's plenty of questions that's (probably) should be asked about how they loaded the trailer & the configurations of both the 5th wheel & trailer tandems.","replyToPid":0}
发表于 2020-4-3 09:02:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"we can't ruin our roads just because we're essential service.","replyToPid":0}
发表于 2020-4-3 09:29:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"If he’s hauling food I thought you could haul over weight but maybe Arizona don’t honor it ","replyToPid":0}
发表于 2020-4-3 12:11:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"just pay the fine. not really sure you can fight it. next time weight reweigh and reweigh again if it's still too heavy go back to the shipper.","replyToPid":0}
发表于 2020-4-3 13:23:22 来自手机 | 显示全部楼层
295387 发表于 2020-04-03 01:29:42 If he’s hauling food I thought you could haul over weight but maybe Arizona don’t honor it
","text":"Hauled some beans across Idaho not to long ago, came up 800 pounds over weight. Since the load was beans, no harm done. So Idaho for sure allows it.","replyToPid":351142}
发表于 2020-4-26 06:09:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"scale the truck before you get in a jam. just pay the ticket and learn something","replyToPid":0}
发表于 2020-4-3 13:18:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"That's pretty shitty ! Only 544 kg over, was it all on one axle or spread over entire load ?","replyToPid":0}
发表于 2020-4-3 10:54:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Right now FMCSA is granting 10% over gross I think???? I know I heard that somewhere.","replyToPid":0}
 楼主| 发表于 2020-4-3 10:15:19 来自手机 | 显示全部楼层
","text":"Thanks brother... I know it’s my fault but thanks for your help.....👍","replyToPid":351132}
GMT+8, 2026-4-16 21:06 , Processed in 0.141307 second(s), 24 queries .
