查看: 349|回复: 20
Traveling from Arizona to Charlotte NC with 20000lbs. Any advice from experienced drivers out there
 楼主| 发表于 2020-4-1 09:17:55 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-4-1 09:24:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get on I40 and go east. not much to that run","replyToPid":0}
发表于 2020-4-1 09:39:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"pick up another load and make it worth it","replyToPid":0}
发表于 2020-4-1 09:31:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"20000 lbs that is no problem bro, I run 42000 lbs.","replyToPid":0}
发表于 2020-4-1 23:27:41 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"666"}
 楼主| 发表于 2020-4-1 09:48:28 来自手机 | 显示全部楼层
462372 发表于 2020-04-01 01:42:37 set your cruise control, sit on your as
","text":"Sure man even if it’s not on cruise I will still sit on my azz driving. Just thinking what do U usually sit on ","replyToPid":350482}
发表于 2020-4-1 09:58:32 来自手机 | 显示全部楼层
871617 发表于 2020-04-01 01:47:24 It’s light so was wondering if it’s going to be bad going through New Mexico coz of winds
","text":"Get the weather channel app if you're concerned about weather. I'm sure you will be fine though.","replyToPid":350483}
发表于 2020-4-1 10:47:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just watch for high cross winds.  A load that light can go over fairly easy.  If it gets really windy DO NOT use cruise control.","replyToPid":0}
发表于 2020-4-1 10:42:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Be careful along \"Accident alley\" (stretch of I-40 between Little Rock, AR & Memphis, TN). Always one bad accident every other day.","replyToPid":0}
发表于 2020-4-1 09:59:11 来自手机 | 显示全部楼层
871617 发表于 2020-04-01 01:48:28 Sure man even if it’s not on cruise I will still sit on my azz driving. Just thinking what do U usually sit on
","text":"not professional if you dont use cruise control. I hate foot pedal driver's.","replyToPid":350486}
发表于 2020-4-1 11:05:51 来自手机 | 显示全部楼层
871617 发表于 2020-04-01 02:11:05 I do use cruise control but my company is like when going through NM try not to use as winds are High
","text":"these are all people who probably don't drive or exaggerate. I run 10,000 lbs across i10 i40 and never had high winds","replyToPid":350498}
 楼主| 发表于 2020-4-1 09:28:34 来自手机 | 显示全部楼层
929659 发表于 2020-04-01 01:24:55 Get on I40 and go east. not much to that run
","text":"Thanks ","replyToPid":350474}
发表于 2020-4-1 09:42:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"set your cruise control, sit on your as","replyToPid":0}
 楼主| 发表于 2020-4-1 09:47:24 来自手机 | 显示全部楼层
577471 发表于 2020-04-01 01:31:57 20000 lbs that is no problem bro, I run 42000 lbs.
","text":"It’s light so was wondering if it’s going to be bad going through New Mexico coz of winds ","replyToPid":350477}
GMT+8, 2026-2-14 14:38 , Processed in 0.074872 second(s), 24 queries .
