查看: 271|回复: 12
17 t680
 楼主| 发表于 2020-3-31 00:24:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"batteries tested good but I cant keep my fridge on while im on 34 it shuts it off. alternator? help.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-31 02:00:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Start your truck every day ","replyToPid":0}
发表于 2020-3-31 00:39:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Newer trucks will do that on the 34 if you leave the fridge on. It's the low voltage disconnect. You need to wire the fridge to a direct power bus that doesn't connect to the low voltage disconnect system. Unfortunately the APU kicks in after the low voltage disconnect is activated."}
发表于 2020-3-31 00:45:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"can you idle at all? apu?","replyToPid":0}
发表于 2020-4-2 03:05:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Run a direct line to batteries, connect to fridge. Problem solved. But crank up about ever 10 hours to keep a good charge on batts ","replyToPid":0}
发表于 2020-3-31 00:36:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"do you have an apu to help keep batteries charged? or, do you have any issues with your inverter?","replyToPid":0}
发表于 2020-3-31 01:14:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Low voltage disconnect.  You either one, need to keep your truck engine running or two,  if you have a APU keep that running.  Most APU's are set up to keep your truck batteries charged.","replyToPid":0}
 楼主| 发表于 2020-3-31 02:31:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"no APU 😭","replyToPid":0}
发表于 2020-3-31 03:31:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"gotta start your truck & run it a while each day then, I cant tell you how long you'd need to maybe a more knowledgeable person could, I have an apu so that's why i dont know how long you'd have to run your truck, but good luck","replyToPid":350113}
发表于 2020-3-31 07:01:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"How many batteries do you have? If only 3 you will need 4. I have 4 batteries and I leave my refrigerator on the coldest setting always. No problems. ","replyToPid":0}
发表于 2020-4-1 23:03:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"you need to go battery direct. trucks are designed to shut off power to bunk when voltage drops in batteries so you have enough juice to start the engine. just need to run your engine for 20 minutes or so to keep your batteries charged.","replyToPid":0}
GMT+8, 2026-2-12 11:05 , Processed in 0.081678 second(s), 24 queries .
