查看: 226|回复: 11
super singles
 楼主| 发表于 2020-3-29 11:50:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"I've heard about the milage advantage, can anyone confirm what their mpg and weight was using super singles? I'm curious to see if there is any noticable advantage to using super singles in the front axle of the tandems and normal double tires in the rear. Does anyone run a combination of super singles and doubles?\n\nany  first hand experience is appreciated.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-29 22:17:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Stay away from super singles it cost in the long run one flat tire and wreck the rim it could cost you$5000 on one flat tire not worth having ","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-3-29 20:56:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Only one reason i will not run them. If one blows out you can't single it out and keep going. Small tire shops dont carry them.  I  have tools too chang my own tires."}
发表于 2020-3-30 02:40:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"They sùck in the snow.","replyToPid":0}
发表于 2020-3-29 21:18:34 来自手机 | 显示全部楼层
931511 发表于 2020-03-29 12:56:49 Only one reason i will not run them. If one blows out you can't single it out and keep going. Small tire shops dont carry them.  I  have tools too chang my own tires.
","text":"That’s a real issue especially in the flatbed world in and out of steel mills ","replyToPid":349690}
发表于 2020-3-30 09:25:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Actually with the improvement of tires these days and lower rolling resistances, the advantages of wide singles over duals is very minimal. Plus that flat issue.  \nAlso, there is the issue of the traction light lighting up quite often.","replyToPid":0}
发表于 2020-3-29 20:56:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"On my 2016 Mack 12 speed auto I’m getting 8 ish hauling around 50k on a flat no aero anything ","replyToPid":0}
发表于 2020-3-29 16:15:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Better fuel in Summer Horrible on Ice in winter. Also if you blow a tire your stuck on side of Road no limping to Nearest Truckstops. So yeah you may save some fuel but gotta ask is that worth Road Assist call and added cost per tire Also loss of Traction in winter and added Chain costs","replyToPid":0}
发表于 2020-3-30 14:10:04 来自手机 | 显示全部楼层
336899 发表于 2020-03-30 01:25:13 Actually with the improvement of tires these days and lower rolling resistances, the advantages of wide singles over duals is very minimal. Plus that flat issue.  \nAlso, there is the issue of the traction light lighting up quite often.
","text":"I never knew some trucks had traction lights.\nI got an '05 Pete 379...no traction light.\nAnd 625 ponies can easily spin my tires. Duals, not singles","replyToPid":349863}
发表于 2020-3-30 19:28:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"maybe just newer trucks do? A light on the dash will light up saying traction loss or wheel spin or something like that.","replyToPid":0}
GMT+8, 2026-2-12 11:04 , Processed in 0.082460 second(s), 24 queries .
