查看: 315|回复: 6
Bad Luck Truck
 楼主| 发表于 2020-3-29 11:44:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just cannot believe my horrible luck I'm having with the truck I purchased from the company I am leased onto. I just spent 2 days and nearly $4,000 in Amarillo, TX. Left the shop this morning who did the work and made it to the POE into New Mexico, was told to shut down until they checked the wind speed, oversize load. Got the green light to move on, fired up the truck, immediately went into debate mode. What a crappy day.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-29 19:28:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Delete it. You will be happy you did. ","replyToPid":0}
发表于 2020-3-29 22:22:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well that’s part of having used truck but a lot times you can make good money with used truck if it’s has a Cummins that’s trouble ","replyToPid":0}
发表于 2020-3-29 12:07:37 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"run manual Regen. used trucks are bad, I would have gotten a new rig had I the capital.\n\nand change the DEF filter."}
 楼主| 发表于 2020-3-30 00:30:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"when the check engine light comes on, it won't let you force regen.","replyToPid":0}
 楼主| 发表于 2020-3-30 00:31:59 来自手机 | 显示全部楼层
462372 发表于 2020-03-29 04:07:37 run manual Regen. used trucks are bad, I would have gotten a new rig had I the capital.\n\nand change the DEF filter.
","text":"yeah, they changed the dpf and the all sensors","replyToPid":349673}
发表于 2020-3-30 20:11:13 来自手机 | 显示全部楼层
932600 发表于 2020-03-29 16:30:59 when the check engine light comes on, it won't let you force regen.
","text":"Newer trucks... if one switch is in the wrong location . It can confuse the computer. A bad ground or sensor can ruin your truck. Two switched even fir bunk lights. Even if they look alike. You must have the correct switch. Visor lights on a Freightliner can leak in rain. This can short out the wires. ","replyToPid":349727}
GMT+8, 2026-2-12 14:14 , Processed in 0.076081 second(s), 24 queries .
