查看: 528|回复: 20
Pete vs Kenny vs western
 楼主| 发表于 2020-3-29 10:18:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"If you had to choose which one would you get and why ? I’m coming from a Freightliner so obviously don’t know sh^*","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-30 14:20:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you looking at new trucks or used trucks?\nI have an '05 Pete 379. 625hp, 18speed, and 3.55 rears.\nNo def.\nPurs like a kitten.\nYes, it's a yellow engine.\n1.7 million on the paint and wires.\nRebuilt drivetrain at 1.3 million, and only because I got a good deal.\n9 airbags underneath on updated suspension... I don't feel a thing going down the road. \nIf I were you, I'd get a good used mostly metal truck with no def, and a warranty.\nJust remember... 379's are riveted together, you can replace individual panels. W9's aren't, your replacing entire sides, or hoods at a time.","replyToPid":0}
发表于 2020-3-30 12:51:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"KW and Pete's have better resale value. if you get a pete or kw do not get the PACCAR engine, go with Cummins.","replyToPid":0}
发表于 2020-3-30 01:24:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Volvo. All day every day ","replyToPid":0}
发表于 2020-4-15 09:37:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"What do you expect... It's a cookie cutter truck. Volvo  Freightliner, now Mack and Western star.\nI saw a new Mack from a distance side view, and at first I thought it was a Volvo.\nMost of them all look the same.\nThey change the grill shape, the headlight shape, and slap a name on it,  and wallah a new truck is born.","replyToPid":0}
发表于 2020-3-29 19:32:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Quit being cool and get a money maker. Freightliner is as good a truck as you’ll find. Best suspension out there. DD15 is a good engine. Mine is at 625000 miles and works perfect. ","replyToPid":0}
发表于 2020-3-30 08:57:57 来自手机 | 显示全部楼层
794377 发表于 2020-03-29 14:15:06 I’ve worked on them all and Peterbilt is by far (most of the time) easiest to work on, with a star car you get a junk steel cab and have to replace your radiator every 6-12 months along with lots of electrical issues and having your headlights not stay adjusted, and sometimes fall out. Kenworth has probably the most comfortable and air tight cab I know of quite a few 10-15 year old kws that the cab is so tight that if you try to shut the door with the window up it won’t shut and if it does your ears pop due to air pressure change, I currently drive a 1989 Peterbilt with 2.5 million miles on it and it drives like a brand new truck .
","text":"My 2015 Western Star has original radiator with zero issues. 625000 miles. No issues with headlights. No electrical issues. Maybe I’m lucky? No wait, this is my third one. All the same. ","replyToPid":349707}
发表于 2020-3-30 02:21:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cool. I'll still take one over anything else. ","replyToPid":349739}
发表于 2020-3-29 10:45:30 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"stay with freightliner paccar is overrated, full of plastic , and dont age well."}
发表于 2020-3-29 10:52:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"I like Freightliner lots more room DD15 is good motor Freightliner shops are better I here ","replyToPid":0}
发表于 2020-3-29 11:10:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"I do love too look at alot of real estate out front but paccar does suck.\ndd15 almost as reliable as s60 imo.\nws used to be a fancy truck not too sure on new ones.\nstick with freightshaker if your used to it already.","replyToPid":0}
 楼主| 发表于 2020-3-29 11:12:14 来自手机 | 显示全部楼层
939763 发表于 2020-03-29 02:45:30 stay with freightliner paccar is overrated, full of plastic , and dont age well.
","text":"My Cascadia pushing 980k time to move on lol ","replyToPid":349651}
 楼主| 发表于 2020-3-29 11:14:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"My Cascadia currently has Cummins .. still alive .. sort of","replyToPid":0}
发表于 2020-3-29 11:16:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"paccar not good imo. but I love looking at alot of real estate out front.\nkwoppers just as good except 680 2000 garbage models. \nws used to be a fancy model not sure about new ones.\ndd15 nearly as reliable as s60.\nall depends on what you like you have to make the payments.","replyToPid":0}
发表于 2020-3-29 21:33:24 来自手机 | 显示全部楼层
670777 发表于 2020-03-29 11:32:27 Quit being cool and get a money maker. Freightliner is as good a truck as you’ll find. Best suspension out there. DD15 is a good engine. Mine is at 625000 miles and works perfect.
","text":"Just bought a 16 cascadia myself","replyToPid":349686}
发表于 2020-3-29 22:23:39 来自手机 | 显示全部楼层
628831 发表于 2020-03-29 03:14:05 My Cascadia currently has Cummins .. still alive .. sort of
","text":"Good luck ","replyToPid":349663}
GMT+8, 2026-4-18 01:34 , Processed in 0.106123 second(s), 24 queries .
