查看: 285|回复: 12
Coronavirus
 楼主| 发表于 2020-3-29 02:13:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"anyone else think that many more people have been infected than the data knows? For alot of people it's probably just a small cough that came and went. If this is true, then that's a good sign because it means the death rate is probably much lower than we believe it to be. Right now it's at 4%. The flu death rate is .5%. I think we borderline collapsed the economy over the flu.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-29 02:44:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think the flu death rate is actually lower than that.  I thought I had seen some numbers of .25% somewhere. Either way, we’ll never know because many people were never tested and have already recovered from it. ","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-3-29 03:57:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"awesome, we haven't even peaked yet and you're ready to declare victory. Premature ejaqulator...","replyToPid":0}
回复 支持 2 反对 2
发表于 2020-3-29 03:31:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Heck I’m sure I’ve already had it. 😆 the county I live in is holding steady at (0) cases.","replyToPid":0}
发表于 2020-3-29 22:12:16 来自手机 | 显示全部楼层
发表于 2020-3-29 11:29:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"the biggest lie about all this pandemic is how bad truckers are effected. Ain't nothing changed for me. These are good times, sadly.","replyToPid":0}
发表于 2020-3-29 04:07:22 来自手机 | 显示全部楼层
462372 发表于 2020-03-28 19:57:36 awesome, we haven't even peaked yet and you're ready to declare victory. Premature ejaqulator...
","text":"You bottom feeders caused this... probably can’t even afford soap or running water. Oh well I’ll make hay while the sun is shining \n\n💵⛄️💵⛄️💵⛄️💵","replyToPid":349593}
发表于 2020-3-29 04:10:46 来自手机 | 显示全部楼层
You bottom feeders caused this... probably can’t even afford soap or running water. Oh well I’ll make hay while the sun is shining 💵⛄️💵⛄️💵⛄️💵
{"replyToPid":349598,"replyTo":"
939922 发表于 2020-03-28 20:07:22 You bottom feeders caused this... probably can’t even afford soap or running water. Oh well I’ll make hay while the sun is shining \n\n💵⛄️💵⛄️💵⛄️💵
","text":"caused what? the economy rewards the efficient. everybody needs a job, that's why there's competition, and in life there's casualties, we can't all be doctors but at the same time we can't all be truckers."}
发表于 2020-3-29 10:07:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's not comparable to the flu. Flu had no patients hospitalized last year, all were diagnosed and released. The death toll was higher than Covid19 but Covid19  takes up to 24 days to be symptomatic and then @60 days to run its course and then more weeks \"to pass.\" \n\nCovid19 is more infectious so more people will get it, ages 20 and up are dying from it, not just Boomers and comorbidities. It is a serious concern, but the \"second and third order of effects\"  are the problems.  \n\nThe Ministries of Propaganda deflected sensible preparations and urged the public to panic but, by yelling fire in a crowded theatre.  What we need is for the medical community to over ride FEMA, CDC, HLS and explain their directives for handling this pandemic.","replyToPid":0}
发表于 2020-3-29 07:10:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I bet they're not telling us the truth, cuz it's enough fears out there already.","replyToPid":0}
发表于 2020-3-29 09:42:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"To answer a question in another thread, \"does anyone know someone  who has Covid19?\"   Yes, one of our trade peer, his wife tested positive. She's over 40 or 50 and in good health. I told him to quarantine.  I hope he stays home until it passes.","replyToPid":0}
发表于 2020-3-29 09:44:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes. you are exactly correct. we need to get ppl back to work asap","replyToPid":0}
GMT+8, 2026-2-12 14:14 , Processed in 0.094073 second(s), 24 queries .
