查看: 41|回复: 0
2017VolvoVNL64T780
 楼主| 发表于 2020-3-27 18:52:52 来自手机 | 显示全部楼层 |阅读模式
VIN: 980414
Hide Access Link: https://prd-forum-api.truckerpath.com/v6/direct_link/?actionCode=AccessTruckAndJobAction&pk=f3b6da981711b9f8b2f&token=3273acffed4ccb05172ef6f610d528e5
mileageV2: 493660
horsePowerV2: 425
engineManufacturerV2: Volvo
engineTypeV2: D13
transmissionV2: Automatic
suspensionV2: Air/Spring
tiresV2: 22.5 LP
wheelsV2: Polished Aluminum
wheelbaseV2: 229
grossVehicleWeightRatingV2: 51200
zipcodeV2: 52404
cityV2: Cedar Rapids
stateV2: IA
condV2: Used
emailV2: rdunlap@gatr.net
makemodelV2: Volvo VNL64T780
phonenoV2: 7632206312
priceV2: 64900
stocknoV2: U6307
latitudeV2: 41.97
longitudeV2: -91.66
modelyearV2: 2017
LucrativId: 3075916
LocationId: 2678946
{"text":"2017 Volvo VNL64T780 77\" stand up sleeper\t\t\t\t\t\nD-13xe, 425HP, i-shift 12 speed  AMT, stick fleet shift\t\t\t\t\t\nDouble bunk, workstation, fridge, cab park heater\t\t\t\t\t\n6 channel ABS, light wgt. s-cam brakes front and rear\t\t\t\t\t\nfixed holland FW35 5th wheel -strong! \t\t\t\t\t\nHeated DAVCO filter, 200 gallon tank! \t\t\t\t\t\nxm radio, TV prep, fleet maintained, detailed, DOT serviced\t\t\t\t\t\nPrevious owner had extended factory warranty ( expired)\t\t\t\t\t\nand much more! Call for details","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":924.0,\"name\":\"\",\"url\":\"\",\"width\":1233.0},{\"description\":\"\",\"height\":849.0,\"name\":\"\",\"url\":\"\",\"width\":1132.0},{\"description\":\"\",\"height\":781.0,\"name\":\"\",\"url\":\"\",\"width\":1041.0},{\"description\":\"\",\"height\":755.0,\"name\":\"\",\"url\":\"\",\"width\":1008.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-3 09:13 , Processed in 0.066695 second(s), 25 queries .
