查看: 66|回复: 0
Want more power out of your E-7/Etech here's the skinny
 楼主| 发表于 2019-1-26 21:21:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"If you have a 91-97 with the Bosch P pump the 1st thing you should do is buy a blixxton. It plugs into the pump and fools the rack to open more. With a 350 they advertised 30% gain and a few ppl have dyno'd it and its true. 100 extra ponies for 300$. Our boost went from 24 to 32-33. You'll need to install a pyro because it will get hot on a pull. If you still need more go go juice you can get stage 2 injectors and and a bigger turbo. We have the 171702 that the 60 series guys love. Were seeing about 42-44psi. And the pyro never goes above 950. Here's a pic of the stock turbo with the 171702","pics":"[{\"description\":\"\",\"height\":240.0,\"name\":\"289/android_1548681678488.png\",\"url\":\"\",\"width\":240.0}]","canComment":true}
GMT+8, 2026-4-17 19:54 , Processed in 0.066280 second(s), 23 queries .
