查看: 166|回复: 5
Quick Question
 楼主| 发表于 2019-6-4 00:10:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"Let say you are making a turn in a truck so in a normal car you would just turn but in a truck, you would wait a little longer before committing to that turn.\n\n\nIs there a rule when it comes to turning say you want to be 2 feet away from the curve before turning?\n\n\nDo you have any advice?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-20 07:02:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"learn how to do button hook turns. It's amazing how much easier it is.","replyToPid":0}
发表于 2019-6-4 05:01:28 来自手机 | 显示全部楼层
654793 发表于 2019-06-03 16:39:03 Not really any trick to it driver. Just turn wide enough u don’t hit anything.
","text":"this answers it","replyToPid":53080}
发表于 2019-6-4 00:39:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not really any trick to it driver. Just turn wide enough u don’t hit anything. ","replyToPid":0}
发表于 2019-6-4 04:56:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"like Ninja said and getting experience by doing it daily.","replyToPid":0}
发表于 2019-6-29 02:28:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you have space, take it Everytime. Don't try to be exact cuz you will NEVER be exact. Your tandems, reffer or not, speed, all the various variables that make turning the truck suck are against you. Just double check your miorrs, look both ways twice, and take up all the room you have available in front of you that you need without hitting anything. NEVER stop in a turn and be aware of your surroundings. Good luck.","replyToPid":0}
GMT+8, 2026-4-18 09:06 , Processed in 0.087520 second(s), 24 queries .
