查看: 152|回复: 7
If you need good laugh 😆 stay safe
 楼主| 发表于 2020-3-27 09:27:45 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[{\"url\":\"http://d2w8udw005hdju.cloudfront.net/video/247264/ios_864562_1585272368933.mp4\"}]","link":"{}","pics":"[{\"description\":\"\",\"height\":345.0,\"name\":\"\",\"url\":\"\",\"width\":200.0}]","canComment":true,"externalShare":false}
发表于 2020-3-27 22:34:27 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You got to watch out for those Chicago overpasses they magically lower themselves 😋. But really a lot of the overpasses do not have clearance heights clearly marked or signs. Stay off the surface streets is the simplest way but even some of the interstates in Chicago have low clearance overpasses. One wrong turn and you might have to end up backing up for blocks and around corners. Personally,  I love the challenge and have never been stuck or had to back out. Yet!\nHint: Enable \"Clearance\" on your Trucker Path map. Also, any road that has train tracks overhead is most likely to be low clearance and those darn things are solid steel not concrete. The low overpass is going to win every time. Also, remember anything on the road, like snow will decrease your clearance heights."}
发表于 2020-3-27 18:06:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Uhhh I guess he forgot about the whole 13'6 thing huh lol","replyToPid":0}
发表于 2020-4-2 03:19:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Chicago low bridge hotline 24/7 is 312 746 8630 🤔 just a phone call can save your a$$ 😁😁😁","replyToPid":0}
发表于 2020-3-27 10:22:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s funny ","replyToPid":0}
发表于 2020-3-27 11:44:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"😂😂😂 made my night ","replyToPid":0}
发表于 2020-3-27 12:06:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤦🏽‍♂️😆😆😆","replyToPid":0}
发表于 2020-3-27 21:47:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"😂😂😂","replyToPid":0}
GMT+8, 2026-2-14 14:38 , Processed in 0.088548 second(s), 24 queries .
