查看: 399|回复: 11
 楼主| 发表于 2020-3-27 04:19:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"I book a load at a rate of $1800 which was posted for $1600 and than the broker calls to cancel it, cause some donskey took the load for $1300! On a 900 miles trip loaded!! So this is the fault of the trucking dispatchers that don’t value their drivers or their trucks on the road. Can someone explain this ****! ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-27 08:33:52 来自手机 | 显示全部楼层
528948 发表于 2020-03-27 00:03:33 Been doing this for about 3 years. And the broker said that someone booked it for $1300 smh
","text":"If the load was booked how did someone else book it? Sounds like their auctioning off loads to see who’s gonna bid the lowest until a driver gets to pick up location. I believe you need a new broker ","replyToPid":348604}
回复 支持 6 反对 1
发表于 2020-3-27 06:23:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"If the load is booked technically you are in agreement and therefore if the broker decides to back out, isn’t there a fee instilled for waisting your time along with a third of the agreed amount due to the party booking(o/o)? The broker backing out of a business deal has to in ALL ways have repercussions towards him or specifically towards to the party backing out of the business deal. When a deal is struck it is struck, This is the only way I see fit to do business with brokers is instill parameters around the booking times and if he does pull the load, pay the party that already booked a percentage. They wanna haggle you, you grab them by the throat. If they complain oh well this kinda crap would not flow in a lawsuit. Judge will see greedy people and will not tolerate it. \nSorry about your issue with the broker,","replyToPid":0}
回复 支持 4 反对 2
发表于 2020-3-27 10:27:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"You are dealing with a bad broker. Booked and signed are 2 different things.if contract is already signed and accepted. its legally binding contract. you could sue them if they back out.   $1.44 mile is getting pretty low. Maybe he wanted to get home real bad.","replyToPid":0}
回复 支持 3 反对 2
发表于 2020-3-27 05:21:37 来自手机
{"replyToPid":0,"replyTo":"","text":"it happens a lot to me some brokers call to cancel over$75 \nsome ásshole o/o"}
支持 5 反对 0
发表于 2020-3-27 07:27:15 来自手机 | 显示全部楼层
518050 发表于 2020-03-26 22:23:32 If the load is booked technically you are in agreement and therefore if the broker decides to back out, isn’t there a fee instilled for waisting your time along with a third of the agreed amount due to the party booking(o/o)? The broker backing out of a business deal has to in ALL ways have repercussions towards him or specifically towards to the party backing out of the business deal. When a deal is struck it is struck, This is the only way I see fit to do business with brokers is instill parameters around the booking times and if he does pull the load, pay the party that already booked a percentage. They wanna haggle you, you grab them by the throat. If they complain oh well this kinda crap would not flow in a lawsuit. Judge will see greedy people and will not tolerate it. \nSorry about your issue with the broker,
","text":"nice theory 👌😉","replyToPid":348573}
发表于 2020-3-27 06:50:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"how do you someone else took it for $1300? speculation I bet...If I was to cancel on you I would not tell you somebody else took it for lower.","replyToPid":0}
发表于 2020-3-27 19:28:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Brokers undercutting rates and or same customer. To top it off drivers running cheap rates add to freight rates remaining low. I’ll deadhead to a different area before running “ negative “ profit freight. ","replyToPid":0}
发表于 2020-3-28 10:59:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Guy I haul for most weeks has a lot of reefer loads paying above $3.00-$3.25 right now. Loading out of the Midwest. The ball is in our court again fellas. \n\n💵","replyToPid":0}
发表于 2020-3-27 10:00:34 来自手机 | 显示全部楼层
518050 发表于 2020-03-27 00:33:52 If the load was booked how did someone else book it? Sounds like their auctioning off loads to see who’s gonna bid the lowest until a driver gets to pick up location. I believe you need a new broker
","text":"Just sharks attack ","replyToPid":348615}
发表于 2020-3-27 06:57:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"It happened to me lots of times brokers booked load and then cancelled. new in o/o doing that","replyToPid":0}
 楼主| 发表于 2020-3-27 08:03:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Been doing this for about 3 years. And the broker said that someone booked it for $1300 smh","replyToPid":0}
GMT+8, 2026-2-5 12:59 , Processed in 0.094207 second(s), 24 queries .
