查看: 161|回复: 4
freightliner cascadia interior cab map/reading lights
 楼主| 发表于 2020-3-26 10:15:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"replaced lights on passenger side...all work fine. replaced on driverside, none work..either through opening door or with pressing click switch.\nare they on separate fuse/circuit? \nany thoughts..?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-26 15:46:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"No good, throw the whole truck away and get a new a one. ","replyToPid":0}
 楼主| 发表于 2020-3-26 22:21:33 来自手机 | 显示全部楼层
670777 发表于 2020-03-26 09:35:16 Replaced with LED? I recently changed my interior to LED and found that they were positive/negative sensitive. Check that out. Also, to the goon who suggested to throw the truck away, there’s one in every crowd.
","text":"thanks for info, and I usually just ignore them.","replyToPid":348378}
发表于 2020-3-26 17:35:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Replaced with LED? I recently changed my interior to LED and found that they were positive/negative sensitive. Check that out. Also, to the goon who suggested to throw the truck away, there’s one in every crowd. ","replyToPid":0}
发表于 2020-3-26 11:09:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’d bet on a separate fuse. ","replyToPid":0}
GMT+8, 2026-3-21 06:09 , Processed in 0.096679 second(s), 25 queries .
