查看: 327|回复: 19
Nebraska weight limit suspended
 楼主| 发表于 2020-3-26 08:08:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"The gov of Nebraska has suspended all weight limits on trucks. Dont let some DOTwith a god complex tell you otherwise...\nhttps://www.1011now.com/content/news/COVID-19-impacting-truckers--569048311.html","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-26 10:34:36 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I would think really hard about using that too hard. These trucks don't handle overloading well. Just 4000 pounds extra can push your stopping distance out 200 feet with smoking brakes because of extra heat. 5% doesn't seem much, but the engineering margins are tight on truck brakes. If you have heavy haul truck, have at it. Otherwise, lay back and be careful. An extra pallet or two of product isn't worth a driver's life."}
回复 支持 7 反对 1
发表于 2020-3-26 10:58:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"u know that weight limit was not because of the brakes right.","replyToPid":0}
发表于 2020-3-26 09:20:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Kansas also suspended their weight limit 2 or 3 days ago...","replyToPid":0}
发表于 2020-3-26 08:38:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just shut down all the pos weight stations and we’ll be good ","replyToPid":0}
发表于 2020-3-27 06:40:25 来自手机 | 显示全部楼层
578388 发表于 2020-03-26 19:50:05 You never smoked your brakes. Congrats. You want to say you have never smelled it or seen it? Ever? And that without overloading? Really? Never? Lol
","text":"I did my annual MVI. 625000 miles. Original brakes. All were over 1/2. And I haul up to 100000 and mostly around 80000. I’d say you need to learn to brake correctly. ","replyToPid":348528}
发表于 2020-3-26 19:39:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"was on that road cause trying to go around scales! ! so like i said my mistake for not being familiar with that hill and being in wrong gear that the engine brake couldnt hold so i needed to over apply the service brakes","replyToPid":0}
发表于 2020-3-26 19:36:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"i have ran over weight foreverrrrrrrr; 1,500- over weight on each spread 3,000- 4,500 over weight over all gross since forever never had no smoking brakes except once on a really crazy back road mistake was mine i saw the smallllll amount of smoke; the second it started went to 5th gear the rest of the way; ","replyToPid":0}
发表于 2020-3-26 17:29:54 来自手机 | 显示全部楼层
578388 发表于 2020-03-26 02:34:36 I would think really hard about using that too hard. These trucks don't handle overloading well. Just 4000 pounds extra can push your stopping distance out 200 feet with smoking brakes because of extra heat. 5% doesn't seem much, but the engineering margins are tight on truck brakes. If you have heavy haul truck, have at it. Otherwise, lay back and be careful. An extra pallet or two of product isn't worth a driver's life.
","text":"Where do you come up with this stuff? 200 feet??!!","replyToPid":348327}
发表于 2020-3-26 19:31:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"jeeeeeez","replyToPid":0}
发表于 2020-3-26 19:32:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"these are the same people why we have this fake virus problem","replyToPid":0}
GMT+8, 2026-2-5 13:00 , Processed in 0.086029 second(s), 24 queries .
