查看: 126|回复: 6
Hate this now. Stuck for repair in Arizona
 楼主| 发表于 2020-3-25 05:15:58 来自手机 | 显示全部楼层 |阅读模式
 楼主| 发表于 2020-3-26 01:16:41 来自手机 | 显示全部楼层
612134 发表于 2020-03-25 04:14:34 Either learn how to do your own repairs. or get used to it!
","text":"Yeah man I am going to start to carry a whole spare windshield in my cab with all tools to fix it so I can do it myself 😹","replyToPid":348014}
发表于 2020-3-25 12:14:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Either learn how to do your own repairs. or get used to it!","replyToPid":0}
发表于 2020-3-25 10:55:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"(Any idea what happened?) 🤔","replyToPid":0}
发表于 2020-3-26 01:20:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"you're stopped over that little crack in your windshield? I would've had it done on home time. anyone says anything to you, it just happened. you're missing loads for a crack? good luck with all that man","replyToPid":0}
 楼主| 发表于 2020-3-27 01:41:26 来自手机 | 显示全部楼层
612134 发表于 2020-03-25 17:20:41 you're stopped over that little crack in your windshield? I would've had it done on home time. anyone says anything to you, it just happened. you're missing loads for a crack? good luck with all that man
","text":"I am on home time bro. I figured that out had to travel a bit with crack to get to home though thanks ","replyToPid":348213}
发表于 2020-3-27 01:51:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"You said stuck in Arizona. sounded like if you were home you wouldn't be stuck","replyToPid":0}
GMT+8, 2026-2-14 17:40 , Processed in 0.065604 second(s), 24 queries .
