查看: 230|回复: 4
Governor Tricks
 楼主| 发表于 2020-3-21 02:55:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"Any tricks to bypass the governor on a 13 peterbilt 388?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-21 14:52:18 来自手机 | 显示全部楼层
929266 发表于 2020-03-20 20:12:05 It has to be programmed.
","text":"You are correct","replyToPid":345989}
发表于 2020-3-21 04:12:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"It has to be programmed.","replyToPid":0}
发表于 2020-3-21 03:08:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cummins?","replyToPid":0}
发表于 2020-4-10 22:03:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"buy the truck, shut the governor off","replyToPid":0}
GMT+8, 2026-3-21 02:08 , Processed in 0.094997 second(s), 24 queries .
