查看: 159|回复: 6
alley dock
 楼主| 发表于 2020-3-19 04:41:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"Any tips for ally dock or videos can't seem to get it right ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-19 06:03:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"One rule! make small corrections. Biggest mistake most make is over correction. Small moves! ","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-3-19 04:48:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"set up truck and a half width away from spot ur backing in put back of trailer 3/4into next slot then hard right(backing not blindside) right when trailer wheels start to stop turning hard left and if timed right ull have minimal pull ups to adjust","replyToPid":0}
发表于 2020-3-19 04:49:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"ally dock being a 90","replyToPid":0}
发表于 2020-3-19 08:46:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Roll your windows down and stick your neck out the window instead of leaving them up listening to Indian hip hop ","replyToPid":0}
发表于 2020-3-19 10:03:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"use the steering wheel","replyToPid":0}
发表于 2020-3-19 12:08:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"go slow, look at the wheels and project where they need to go.","replyToPid":0}
GMT+8, 2026-4-18 08:15 , Processed in 0.062294 second(s), 24 queries .
