查看: 67|回复: 5
My truck
 楼主| 发表于 2020-3-18 00:36:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"thetrucker.com","videos":"[]","link":"{\"picture\":{\"description\":\"\",\"height\":96.0,\"name\":\"\",\"url\":\"https://secure.gravatar.com/avatar/83e5da3e48d874651c84b98932678164?s=96&d=mm&r=g\",\"width\":96.0},\"title\":\"‘Pride in my ride’: Arkansas trucker brings solar power, style to his ‘96 Peterbilt | TheTrucker.com\",\"type\":\"GENERAL\",\"url\":\"https://thetrucker.com/pride-in-my-ride-arkansas-trucker-brings-solar-power-style-to-his-96-peterbilt/\",\"valid\":true}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-18 02:19:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just read the article. Couple questions. Where do you get your $20000/year savings in fuel? A truck uses about a gallon of fuel per hour. $20000/$3 a gallon is 6666 gallons a year. You were idling 125 hours a week? Also, you’re not getting 8.4 mpg on a 3406 Cat. I’ve driven them. You are getting 5.5-6. The article was riddled with BS, and I’m not sure why. ","replyToPid":0}
 楼主| 发表于 2020-3-18 04:12:10 来自手机 | 显示全部楼层
670777 发表于 2020-03-17 18:19:56 I just read the article. Couple questions. Where do you get your $20000/year savings in fuel? A truck uses about a gallon of fuel per hour. $20000/$3 a gallon is 6666 gallons a year. You were idling 125 hours a week? Also, you’re not getting 8.4 mpg on a 3406 Cat. I’ve driven them. You are getting 5.5-6. The article was riddled with BS, and I’m not sure why.
","text":"I’d be happy to sit down with you and go over the numbers it’s not my fault you get bad fuel mileage ","replyToPid":344782}
发表于 2020-3-18 02:31:08 来自手机 | 显示全部楼层
","text":"Best I got out of my 94 379 6NZ W/a 13 spd , 3.55 rears, 290 w.b and 90\" bunk was 6.2 loaded open flat with around 42k on the deck.","replyToPid":344782}
 楼主| 发表于 2020-3-18 04:04:23 来自手机 | 显示全部楼层
","text":"I told them my savings was around 15 I also to them that that cost included some  figures I put together for wear and tear from idling all the time not just fuel dollars per day in wear and tear ","replyToPid":344782}
发表于 2020-3-18 20:42:50 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I’ve been an owner operator since 2002. I’ve always driven Detroit engines since then. Before that I drove Cats. And MPG is my game. I drive 60-65 mph and know how to get mileage. I don’t idle truck. Etc etc. And as I said. You are lying if you say you are doing 8.4. Especially an average! And I’m not picking on Cat engines. They were great for some people. I personally have never owned one because of the very high cost of repair and terrible fuel economy. Another driver posted on this same thread that the BEST he got was 6.2. If you’re going to tell BS stories, be prepared to be called out. Also, the article did say $20,000.00/year. Not 15k. And how can you tell wear and tear figures? As best as I can tell by your numbers you’re estimating wear and tear to be about $15,000.00/year? $75,000.00 every 5 years? "}
GMT+8, 2026-2-5 09:40 , Processed in 0.077528 second(s), 24 queries .
