查看: 46|回复: 0
2016 International? Durastar? 4300 4X2
 楼主| 发表于 2020-3-17 21:13:09 来自手机 | 显示全部楼层 |阅读模式
mileageV2:
{"text":"LEASE MAINTAINED/RUST FREE AZ TRUCK/AIR DRIVERS SEAT/2 MAN PASSENGER SEAT/26FT DRY VAN/102W/102H/3000 LB ALUM GATE RAMP COMBO    2016 International® Durastar® 4300 4x2If you've got a job to do, trust the International® DuraStar® to do it right. In the world of medium-duty trucks, the DuraStar goes beyond efficiency, durability and driver satisfaction. Built completely of commercial-grade components and materials, its quality construction and materials can handle the action: Whether you're towing cars in a snowstorm, repairing downed power lines or racing to a fire, count on the DuraStar to answer the call, every time.EFFICIENCYThe DuraStar® was built with drivers in mind — and their businesses, too. Standard service-related features all help prevent costly breakdowns and keep you running longer.The Diamond Logic® electrical system streamlines the process of integrating equipment into the chassis electrical system, giving you on-board diagnostics and a range of programmable features and safety interlocks.DURABILITYALL COMMERCIAL-GRADE Built completely of commercial-grade components and materials, DuraStar® boasts a nearly indestructible huck-bolted chassis and a sturdy cab that exceeds SAE rollover safety regulations.DRIVER SATISFACTIONA panoramic, swept-back windshield maximizes the driver's range of vision. It's also heated to melt snow and ice, for a clear, safe drive.Well-designed details like easy-grab handles, non-slip stairs and wide door openings keep your drivers safe when they're on the move.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-3 07:13 , Processed in 0.083203 second(s), 25 queries .
