查看: 340|回复: 10
A question about waiting at the loaders and receivers
 楼主| 发表于 2019-6-3 05:37:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"If you are stuck at a place waiting to be unloaded or waiting for a load and it's time to sleep what do you do?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-3 05:45:00 来自手机 | 显示全部楼层
发表于 2019-6-3 08:51:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Troll hurr","replyToPid":0}
发表于 2019-6-3 10:55:34 来自手机 | 显示全部楼层
发表于 2019-6-3 06:29:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"sleep ","replyToPid":0}
发表于 2019-6-3 06:28:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"sleep","replyToPid":0}
发表于 2019-6-3 07:08:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I sleep","replyToPid":0}
发表于 2019-6-3 08:36:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"set an alarm for 2 hours, and sleep.","replyToPid":0}
发表于 2019-6-3 09:53:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Look for other loads","replyToPid":0}
发表于 2019-6-3 10:44:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your out of hours then sleep until loaded. Then go off duty to drive to nearest parking. Explains in notes on ELD what you had to do. Make sure BOL has time stamp to back you up. I note on BOL my arrival and departure & have them sign","replyToPid":0}
GMT+8, 2026-4-15 14:10 , Processed in 0.068673 second(s), 24 queries .
