查看: 168|回复: 2
Witch part don’t you understand?
 楼主| 发表于 2020-3-13 06:08:29 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":679.0,\"name\":\"\",\"url\":\"\",\"width\":679.0}]","canComment":true,"externalShare":false}
发表于 2020-3-13 08:06:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Which, witch or which don't you understand?","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-3-14 02:04:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Came from ole school, don’t give a rats azz if you drive a 9 speed 10 speed 13 speed or automatic, it doesn’t change a single solitary thing and it dang sure don’t make you any more or less a man a woman or a professional, so you idiots that are having delusions of grandeur because your Truck is older than you are and still has a stick coming out of the floor ( for your pleasure) i might add    need to find new ways to measure the length of your sticks because no one cares. ","replyToPid":0}
GMT+8, 2026-2-12 19:41 , Processed in 0.067434 second(s), 24 queries .
