查看: 228|回复: 8
Haul Truck Needed ASAP. Haul trailer from Franklin, KY to San Angelo, TX.
 楼主| 发表于 2020-3-12 09:05:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"Our toterhome went into “limp” mode and scanner not showing any trouble codes.  We are stuck in Franklin, KY and our trailer absolutely has to be in San Angelo, TX tomorrow by noon.  Trailer is 53’x102” weight about 80-85k lbs.  Need to be reliable and truck able to make a solid run.  Respond with what you have and how much you want.  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-13 06:20:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hate when my 🍆  goes into “limp” mode ","replyToPid":0}
发表于 2020-3-12 10:03:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"you are pulling 85k with a toterhome ?","replyToPid":0}
发表于 2020-3-12 09:57:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"(Good luck getting through Arkansas w/ that weight.)","replyToPid":0}
发表于 2020-3-12 09:37:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"What is it you need? A triaxle truck power only to pull it? We are a heavy haul outfit and you can call the office down in Knoxville Tn to see if they can do something for you? 865 540 4409","replyToPid":0}
发表于 2020-3-12 09:38:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh yea ask for Jason or James in heavy haul division. My name is allen. Hope that helps. ","replyToPid":0}
 楼主| 发表于 2020-3-12 10:14:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes tri axle.  Thank you. ","replyToPid":0}
 楼主| 发表于 2020-3-12 10:15:29 来自手机 | 显示全部楼层
705502 发表于 2020-03-12 01:57:07 (Good luck getting through Arkansas w/ that weight.)
","text":"We run through Arkansas every week no problem. ","replyToPid":342357}
 楼主| 发表于 2020-3-12 10:15:46 来自手机 | 显示全部楼层
871816 发表于 2020-03-12 02:03:47 you are pulling 85k with a toterhome ?
","text":"Custom toter.  ","replyToPid":342358}
GMT+8, 2026-2-5 09:11 , Processed in 0.090216 second(s), 24 queries .
