查看: 306|回复: 10
turning up
 楼主| 发表于 2019-6-3 03:47:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"Thinking of \"turning up\" my Cummins... I'd like to see about 675-700+ hp and 2200 ft lb of torque...\n I frequently haul 45000+ with a International pro star. Any thoughts/suggestions other than get a different truck? LOL","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-4 04:11:47 来自手机 | 显示全部楼层
发表于 2019-6-17 12:08:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm running a 2014 Cascadia DD-15 with a fuller 10-speed. I plan to open it up after my last payment. No plan for deletes, too costly if you get caught.","replyToPid":0}
 楼主| 发表于 2019-6-8 07:14:26 来自手机 | 显示全部楼层
83379 发表于 2019-06-07 23:11:55 Cummins junk! I turn it to a salvage yard! My 425 mechanical cat will out run your 700hp Cummins
","text":"no doubt... I just run with what I have! Been good to me so far...\nThanks for your input!","replyToPid":59095}
 楼主| 发表于 2019-6-4 14:11:14 来自手机 | 显示全部楼层
26080 发表于 2019-06-03 20:10:08 If you want to delete check out Rawze.com
","text":"Thanks, but I already have delete... helped out the truck alot!  Single best investment I've made!","replyToPid":53478}
发表于 2019-6-4 04:10:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you want to delete check out Rawze.com","replyToPid":0}
 楼主| 发表于 2019-6-4 14:14:52 来自手机 | 显示全部楼层
710178 发表于 2019-06-03 20:11:47 Do not turn your truck up you may break the law
","text":"I wasn't aware there were laws governing how powerful a truck that I own could be...let me know when and where you find that one in the books! 😊","replyToPid":53481}
发表于 2019-6-8 07:11:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cummins junk! I turn it to a salvage yard! My 425 mechanical cat will out run your 700hp Cummins ","replyToPid":0}
 楼主| 发表于 2019-6-8 07:15:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Someday when I grow up, I hope to get a Pete. With a CAT....😏😁","replyToPid":0}
发表于 2019-6-9 09:33:30 来自手机 | 显示全部楼层
707101 发表于 2019-06-07 23:15:51 Someday when I grow up, I hope to get a Pete. With a CAT....😏😁
","text":"For what? It’s all junk pete kw volvo same junk! Not what it used to be! ","replyToPid":59099}
发表于 2019-6-10 03:25:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Shhhhh There everywhere. jk 😳😳😳","replyToPid":0}
GMT+8, 2026-4-15 15:47 , Processed in 3.034295 second(s), 24 queries .
