查看: 287|回复: 20
Battery issues
 楼主| 发表于 2020-3-12 00:03:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does battery smell horrible when its get older?  Seems like smelling from battery i am not shure, and cabin is smelling also bad, making headache.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-12 00:29:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get them changed ASAP.  I bet one is swelling. Could end badly.  ","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-3-12 00:56:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Does it smell like rotten eggs?","replyToPid":0}
发表于 2020-3-12 01:52:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep taking deep breaths, maybe your grammar will improve.","replyToPid":0}
发表于 2020-3-12 02:20:23 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You have a battery shorted out. The plates collapse and fall to the bottom inside battery. Open battery cover. Find the hot battery. Trickle an entire gallon of water over it. Then undo the connections CAREFULLY so as to not creat a spark by touching your wrench from positive post to anything metal. Then black tape the terminals. You’ll then be operating on 3 batteries. You’ll be fine until you get to a shop. Done this many times over the years. "}
发表于 2020-3-12 00:11:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have it tested for carbon monoxide yes batteries can smell. \nDefinitely get the cab tested for carbon monoxide that will kill you bro","replyToPid":0}
发表于 2020-3-13 14:00:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rotten eggs smell is bad batteries.","replyToPid":0}
发表于 2020-3-12 11:42:12 来自手机 | 显示全部楼层
670777 发表于 2020-03-11 18:20:23 You have a battery shorted out. The plates collapse and fall to the bottom inside battery. Open battery cover. Find the hot battery. Trickle an entire gallon of water over it. Then undo the connections CAREFULLY so as to not creat a spark by touching your wrench from positive post to anything metal. Then black tape the terminals. You’ll then be operating on 3 batteries. You’ll be fine until you get to a shop. Done this many times over the years.
","text":"This is dumb. If 1 fails replace them all together.","replyToPid":342138}
发表于 2020-3-12 01:46:42 来自手机 | 显示全部楼层
{"replyToPid":342119,"replyTo":"
907952 发表于 2020-03-11 16:56:36 Does it smell like rotten eggs?
","text":"it smells like a puzzy of tyrone75's wife, like a rotten fish"}
发表于 2020-3-12 05:39:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drill a hole in the top of the battery and slurp some juice out. It’s ph balanced","replyToPid":0}
发表于 2020-3-12 00:26:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"ah it's nothing. keep driving!","replyToPid":0}
发表于 2020-3-12 02:16:53 来自手机 | 显示全部楼层
929266 发表于 2020-03-11 17:52:34 Keep taking deep breaths, maybe your grammar will improve.
","text":"LOL!!!","replyToPid":342134}
发表于 2020-3-12 02:25:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Over heated batteries will smell bad\nProbably running on fewer batteries than the 4 you got\nTime for new ones","replyToPid":0}
GMT+8, 2026-2-5 08:09 , Processed in 0.088813 second(s), 24 queries .
