查看: 331|回复: 23
Feedback
 楼主| 发表于 2020-3-11 17:31:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can somebody tell me why you drivers who speed up when you're being passed, why you do that? It's juvenile, it's unprofessional and it pisses me off.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-11 20:58:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Those who do so are not truck drivers, they are steering wheel holders with a four-wheeler mentality: Can't let the big, slow truck get in front of me!!!","replyToPid":0}
回复 支持 11 反对 2
发表于 2020-3-11 23:02:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe they don’t actually “speed up”. Maybe they just return to their cruising speed. If you lose momentum on a hill you will regain that on a flat surface. If you can’t get around them then that’s on you. Maybe you should get a faster truck and stop being a whiny beyotch","replyToPid":0}
回复 支持 6 反对 4
发表于 2020-3-12 05:25:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"You'll will only do it once to me. I'll run you into the back of the next truck","replyToPid":0}
发表于 2020-3-11 21:59:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s your new drivers now days they can’t just wait until your pass  to speed up down south is probably the worst ","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-3-12 00:25:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you passing in a efficient matter this will not happen hammer down when passing ","replyToPid":0}
发表于 2020-3-11 21:51:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"J.B. Hunt intermodal ","replyToPid":0}
发表于 2020-3-14 00:29:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"I can pass you with a full load while you’re empty going uphill because my truck > yours. This applies to most but not all. There are a small percentage of trucks who are stronger than mine. My truck probably gets better fuel mileage too 🤣","replyToPid":0}
发表于 2020-3-12 09:01:46 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Because you’re waiting to pass at an uphill incline carrying more weight than them and are too $tupid to pay attention to detail."}
发表于 2020-3-12 05:42:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"When someone thinks they got a fast truck I open it up and blòw they doors clean off and laugh 😆 ","replyToPid":0}
发表于 2020-3-12 01:35:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"A lot depends on weight. \n\nUp here a lot of guys run maxed out. \n\nIf your going up hill. He who has less weight or more torque wins. \n\n","replyToPid":0}
发表于 2020-3-11 21:12:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve reserved a special place for these people. ","replyToPid":0}
发表于 2020-3-12 00:35:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"you mad bro?","replyToPid":0}
发表于 2020-3-12 02:24:28 来自手机 | 显示全部楼层
669771 发表于 2020-03-11 15:02:44 Maybe they don’t actually “speed up”. Maybe they just return to their cruising speed. If you lose momentum on a hill you will regain that on a flat surface. If you can’t get around them then that’s on you. Maybe you should get a faster truck and stop being a whiny beyotch
","text":"LMAO","replyToPid":342085}
GMT+8, 2026-2-12 15:58 , Processed in 0.068275 second(s), 24 queries .
