查看: 117|回复: 5
antennas
 楼主| 发表于 2020-3-10 13:26:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"witch is the best ones , recomend ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-10 14:34:10 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Apparently a broomstick would suffice....lol (witch) 🧹🧙‍♀️  Depending on if you need a bird perch or not depends on WHICH antenna I'd RECOMMEND."}
发表于 2020-3-10 14:09:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tv? XM? radio? CB? \nI assume CB. don't forget coax as well as the CB with a peak and tune done right matters too.","replyToPid":0}
发表于 2020-3-10 13:50:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"What truck are you runnin? \n\nCheers!","replyToPid":0}
发表于 2020-3-10 23:59:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Predator 10-K","replyToPid":0}
发表于 2020-3-20 19:53:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"5 ft firestick","replyToPid":0}
GMT+8, 2026-2-5 03:49 , Processed in 0.082594 second(s), 24 queries .
