查看: 301|回复: 27
swift drivers.
 楼主| 发表于 2020-3-10 05:34:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"PSA- No matter how you vote down any negative posting of swift, or follow accounts around nobody will ever give you social media points for it. Disliking posts doesn't matter to me, nor do your responses. in short, swift will never stop being an embrassment to the industry and nobody will ever care about your hurt feelings on an app. So by all means, dislike or like and follow me around, you still will be the sickness in this industry. There is a reason for all my pictures of swift crashing or screwing up. Drivers for swift make it easy because there is plenty. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-10 06:34:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nobody cares about your dislike for swift either, chum.","replyToPid":0}
回复 支持 8 反对 6
发表于 2020-3-10 07:00:27 来自手机 | 显示全部楼层
808178 发表于 2020-03-09 22:40:58 I'm sorry a Swift driver hurt you, heartbreak can be tough; but it wasn't all of us. Plus no one cares what a little biátch like you thinks anyway. You're just not relevant if all you do is hate on Swift; it's old... ... ...
","text":"It’s not old, it’s a constant problem! Right now I’m looking at Swift truck #202032. Reefer. This ásshole came flying into the parking lot wide open, cut a u turn and parked next to the scale in everybody’s way. D-bag went inside for about twenty minutes and now he’s back in the truck, with the parking lot mostly empty. Could have pulled in at a normal safe speed and parked in a spot but instead he’s a menace to everyone here. Fúck you, fúck Swift, and fúck everyone affiliated with that dogshít company.","replyToPid":341524}
回复 支持 7 反对 4
发表于 2020-3-10 08:35:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm not a Swift driver but I've seen just as many o/o's do Stoopid shït too.\n\nI do dumb stuff too. we all do. if you haven't, you ain't been out here long.","replyToPid":0}
回复 支持 6 反对 4
发表于 2020-3-10 07:41:05 来自手机 | 显示全部楼层
{"replyToPid":341564,"replyTo":"
808178 发表于 2020-03-09 23:39:09 This comment has been deleted
","text":"Swift drivers are nothing more than a nuisance on our nations public roadways. Gotta be low IQ to work there."}
回复 支持 5 反对 5
发表于 2020-3-10 07:28:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Swift is the armpit of trucking. ","replyToPid":0}
回复 支持 6 反对 4
发表于 2020-3-10 07:38:26 来自手机 | 显示全部楼层
927962 发表于 2020-03-09 23:00:27 It’s not old, it’s a constant problem! Right now I’m looking at Swift truck #202032. Reefer. This ásshole came flying into the parking lot wide open, cut a u turn and parked next to the scale in everybody’s way. D-bag went inside for about twenty minutes and now he’s back in the truck, with the parking lot mostly empty. Could have pulled in at a normal safe speed and parked in a spot but instead he’s a menace to everyone here. Fúck you, fúck Swift, and fúck everyone affiliated with that dogshít company.
","text":"you must be a rookie if you've only seen Swift do something like that lol","replyToPid":341541}
回复 支持 4 反对 5
 楼主| 发表于 2020-3-10 07:43:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"we can see swift drivers outing themselves by the butthurt level in the post 😂. My fault, I forgot you swift drivers are less then bright","replyToPid":0}
回复 支持 5 反对 4
发表于 2020-3-10 06:40:58 来自手机
{"replyTo":"","text":"I'm sorry a Swift driver hurt you, heartbreak can be tough; but it wasn't all of us. Plus no one cares what a little biátch like you thinks anyway. You're just not relevant if all you do is hate on Swift; it's old... ... ...","replyToPid":0}
支持 2 反对 4
发表于 2020-3-10 08:16:07 来自手机 | 显示全部楼层
664930 发表于 2020-03-09 23:43:16 we can see swift drivers outing themselves by the butthurt level in the post 😂. My fault, I forgot you swift drivers are less then bright
","text":"Talk about less than bright! Read thru the comments, the only bûtthùrt in this post is you anti-swift hómõ's! lmao!!!","replyToPid":341570}
回复 支持 2 反对 3
发表于 2020-3-10 08:19:04 来自手机 | 显示全部楼层
{"replyToPid":341583,"replyTo":"
808178 发表于 2020-03-10 00:09:08 This comment has been deleted
","text":"May 2001. Around the time your nùts dropped. MAYbe. You are a cartoon, AtheistTrucker, and the majority of us are laughing at you, and wish we could bleed you. Slowly. 😃😃😃"}
回复 支持 3 反对 2
发表于 2020-3-10 08:22:35 来自手机 | 显示全部楼层
927962 发表于 2020-03-10 00:19:04 May 2001. Around the time your nùts dropped. MAYbe. You are a cartoon, AtheistTrucker, and the majority of us are laughing at you, and wish we could bleed you. Slowly. 😃😃😃
","text":"bring it","replyToPid":341590}
回复 支持 0 反对 3
GMT+8, 2026-2-13 02:22 , Processed in 0.122466 second(s), 24 queries .
