查看: 411|回复: 14
This app is a piece of crap, it crashed when I need directions at a critical time. I thought, I only had a subscriptio
 楼主| 发表于 2020-3-9 09:25:20 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1280.0,\"name\":\"\",\"url\":\"\",\"width\":960.0}]","canComment":true,"externalShare":false}
发表于 2020-3-9 09:31:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"was you needing directions to your sofa?","replyToPid":0}
回复 支持 8 反对 1
发表于 2020-3-9 10:07:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you really have to take a selfie just to complain about THAT?","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-3-9 09:43:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"I say, old boy...did you have a stroke in the middle of that last sentence? I hope you pull through, chap! Cheerio! ","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-3-9 09:27:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"It wasn't always a pos. It is getting worse every update.  ","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-3-9 11:50:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"I can’t believe you would pay for a garbage app like this instead of investing in a garmin Dēzl or planning on a map ","replyToPid":0}
发表于 2020-3-9 10:01:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Beware of posting selfies on here.. just sayin’.","replyToPid":0}
发表于 2020-3-9 11:38:23 来自手机 | 显示全部楼层
834825 发表于 2020-03-09 02:07:54 Did you really have to take a selfie just to complain about THAT?
","text":"sometimes you need to. dang that place is a mess i wonder what his truck looks like 🤦‍♂️","replyToPid":341286}
发表于 2020-3-11 04:32:19 来自手机 | 显示全部楼层
920617 发表于 2020-03-10 20:30:27 What is the point of soliciting a prôstitute if your dïck doesn't get hard enough to access the twät ?
","text":"c0caine can fix that.","replyToPid":341851}
发表于 2020-3-9 15:35:52 来自手机 | 显示全部楼层
926397 发表于 2020-03-09 01:43:31 I say, old boy...did you have a stroke in the middle of that last sentence? I hope you pull through, chap! Cheerio!
","text":"🤣","replyToPid":341276}
发表于 2020-3-9 16:05:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"what is the point of the offline maps if they still need the online services to access it?","replyToPid":0}
发表于 2020-3-9 10:01:46 来自手机 | 显示全部楼层
699558 发表于 2020-03-09 01:31:30 was you needing directions to your sofa?
","text":"😂 ","replyToPid":341275}
发表于 2020-3-9 12:11:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"But first lemme take a sellllfffiiieee!!!@$$@!","replyToPid":0}
GMT+8, 2026-3-21 14:30 , Processed in 2.439004 second(s), 32 queries .
