查看: 167|回复: 6
dispute dot
 楼主| 发表于 2020-3-7 22:17:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"Wondering if disputing a warning that dot wrote me up on is worth it? I have found proof of what I told them. My eld messed up and keeptruckin told me to just put notes where it messed up and I'd be ok. Dot said no.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-8 05:34:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Most of them DOT don’t know what there looking at anyway I would write that dot in that state and tell them there wrong but it probably won’t help but they should know your doing it right ","replyToPid":0}
发表于 2020-3-8 02:00:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don't worry about it. In my personal experience most companies, even good ones, don't give two sh!ts about your CSA points as long as they weren't acquired from a moving violation, an accident, or something that could cause an accident, especially if you have a fair and reasonable explanation for those points.","replyToPid":0}
 楼主| 发表于 2020-3-8 06:54:29 来自手机 | 显示全部楼层
295387 发表于 2020-03-07 21:34:06 Most of them DOT don’t know what there looking at anyway I would write that dot in that state and tell them there wrong but it probably won’t help but they should know your doing it right
","text":"Thanks I will do that.","replyToPid":340605}
发表于 2020-3-8 08:23:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it's a warning to something you can't control on your elog...just let your company know and not sweat it unless the company gives you grief.","replyToPid":0}
发表于 2020-3-8 07:16:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can fight a ticket, you can't fight a warning","replyToPid":0}
发表于 2020-3-8 11:04:07 来自手机 | 显示全部楼层
724453 发表于 2020-03-07 23:16:33 you can fight a ticket, you can't fight a warning
","text":"True. Case closed.","replyToPid":340628}
GMT+8, 2026-2-13 04:06 , Processed in 0.261605 second(s), 24 queries .
