查看: 381|回复: 20
GPS
 楼主| 发表于 2020-3-6 05:00:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"Looking for recommendations on purchasing a trucker GPS","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-6 06:30:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go with the truckers garmin","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-3-6 06:32:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin is the best brand to go with.","replyToPid":0}
发表于 2020-3-6 06:56:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Save your money, use google maps and a paper atlas. Google maps is not truck specific but your atlas will tell you where you can’t go. Google maps has far more resources integrated in its system than all other gps’s combined. ","replyToPid":0}
回复 支持 2 反对 2
发表于 2020-3-6 10:04:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin Dezl. 7\" screen, voice command, lifetime updates, and you can buy them with or without built-in dash cam. Also, I'd recommend using it in conjunction with Google maps and an up to date atlas.","replyToPid":0}
发表于 2020-3-6 10:26:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"My husband and I are OTR long haul drivers.  We have used the Garmin Truckers GPS for 5 years now.  It comes with lifetime updates and you can set it for hazardous/nonhazardous, low clearance, different trailer length, as well as, truck weighs plus many many more.  I tried the Rand McNally and it was not as user friendly as the Garmin.  And I still rely on my atlas too. ","replyToPid":0}
发表于 2020-3-6 07:22:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rand Mcnally's is the best truck GPS","replyToPid":0}
发表于 2020-3-6 08:53:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin!!!","replyToPid":0}
发表于 2020-3-6 09:24:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buy a truck road Atlas,  and learn to use it. \n\nCheers","replyToPid":0}
发表于 2020-3-6 10:12:37 来自手机 | 显示全部楼层
669593 发表于 2020-03-06 02:11:53 Got the TND Rand McNally it’s Garbage 🗑 I use the Trucker Path GPS it’s way Better
","text":"I’m buying a Garmin now ","replyToPid":339569}
发表于 2020-3-6 09:07:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"garmin","replyToPid":0}
发表于 2020-3-6 10:11:53 来自手机 | 显示全部楼层
735313 发表于 2020-03-05 23:22:00 Rand Mcnally's is the best truck GPS
","text":"Got the TND Rand McNally it’s Garbage 🗑 I use the Trucker Path GPS it’s way Better ","replyToPid":339515}
GMT+8, 2026-3-22 02:09 , Processed in 0.121214 second(s), 24 queries .
