查看: 277|回复: 22
When to jump ship?
 楼主| 发表于 2020-3-4 23:31:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"current company is crying about fuel usage, yet they keep sending me on long trips. Long trip or jump ship?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-3-5 01:42:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do the math for them, show odometer reading before fueling and calculate miles. If you show the work behind your work company should not have a problem. If they do, slowly make your way to the door. No sudden movements, or you could f yourself.","replyToPid":0}
发表于 2020-3-5 04:10:08 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Follow Bugs' advice. If that's not good enough for your company, find another company before you quit this one."}
发表于 2020-3-5 04:33:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ï'M Å PÈRVÉRTÈD ÇHĪLD MÖLÈSTING PÈDOPHÏLE","replyToPid":0}
回复 支持 0 反对 3
发表于 2020-3-5 07:14:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"use cruise control, haha","replyToPid":0}
发表于 2020-3-4 23:53:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Please be more specific. Is your company claiming that something you're doing is causing worse fuel economy than they would like or is it something else?","replyToPid":0}
发表于 2020-3-5 03:31:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"call ndl in sellersburg in. great company","replyToPid":0}
发表于 2020-3-5 04:32:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"If they are worried about current fuel prices I would be looking for a new job.","replyToPid":0}
 楼主| 发表于 2020-3-5 05:18:51 来自手机 | 显示全部楼层
932078 发表于 2020-03-04 20:33:49 Ï'M Å PÈRVÉRTÈD ÇHĪLD MÖLÈSTING PÈDOPHÏLE
","text":"not from the posts I have seen from the actual Navy Gator...","replyToPid":338968}
发表于 2020-3-5 06:14:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try applying to one of the major carriers. Most of them, like Schneider, prime, warren, Crete, or the others will accept your 1 year of driving as experience and will treat you better","replyToPid":0}
发表于 2020-3-5 12:27:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Driver, what do you care? If they are to dimwitted to figure out the basics of running a truck it sure as hell is not your job to do this for them. \n\nLong trip, short trip, heavy, light, tolls, no tolls, idle time or apu fuel consumption... all NOT your problem.\n\nThis is for them to figure out if the load is worth it... Again if they are to stoooopid to figure this s**t out, it is on them.\n\n Get your exoerince, buy your own rig, live life and run the truck how you want.   \n\nGood luck and screw those nickel and dime chumps. \n\nCheers!"}
 楼主| 发表于 2020-3-5 01:33:52 来自手机 | 显示全部楼层
929273 发表于 2020-03-04 15:53:55 Please be more specific. Is your company claiming that something you're doing is causing worse fuel economy than they would like or is it something else?
","text":"The company is saying that I need to save fuel, but they keep sending me on long trips with heavier loads.","replyToPid":338879}
 楼主| 发表于 2020-3-5 01:43:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"also they have drivers quitting.","replyToPid":0}
GMT+8, 2026-2-15 04:26 , Processed in 0.098515 second(s), 24 queries .
