查看: 48|回复: 0
SCANIA Immobilizer
 楼主| 发表于 2019-1-26 19:17:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"#1 \nHi and good day for everybody \nI am doing workshop business and hope can get some advice from here for 2010 up all scania G R P series from UK come with immobilizer and cant be disable like volvo PTT develop just switch it off by click the button...\ni hear and try about encryptor and decryptor with VCI 3, still the same result\nand correct me if i am wrong...\n\n1. Immo should be off when replace any used engine ECU and coo right ?\n\n2. Engine ecu is control by COO6 and coo6 with immo but engine ecu is not..?\n\n3. Any other way to bypass or disable immo ? \n\nThanks\nBest Regards","pics":"[]","canComment":true}
GMT+8, 2026-4-17 08:14 , Processed in 0.074647 second(s), 23 queries .
