查看: 118|回复: 5
wake up
 楼主| 发表于 2020-2-27 23:03:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"Snoqualmie morning","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1314.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true,"externalShare":false}
发表于 2020-2-27 23:10:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks pretty ","replyToPid":0}
发表于 2020-2-27 23:14:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Very beautiful 👍","replyToPid":0}
 楼主| 发表于 2020-2-27 23:14:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"it is until you find out the hard way you forgot to tighten the bottom hose on you power steering pump after changing the filter","replyToPid":334127}
发表于 2020-2-27 23:24:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did u loose alittle oil","replyToPid":0}
 楼主| 发表于 2020-2-28 00:00:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"only all of it and I just used my last bit changing the filter, but a gallon of bar and chain oil later from the local outdoors store in the middle of nowhere and I'm on the road again¯\\_(ツ)_/¯","replyToPid":334136}
GMT+8, 2026-4-18 11:48 , Processed in 0.075949 second(s), 23 queries .
