查看: 225|回复: 6
wt oil in the air tanks!
 楼主| 发表于 2020-2-25 23:48:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"this truck is junk on my way to Vegas to drop off my stuff then Chicago to give this truck back.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":954.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0},{\"description\":\"\",\"height\":954.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true,"externalShare":false}
发表于 2020-2-26 00:40:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Air compressor is bad pushing oil there’s probably a lot miles on that truck I just replaced mine ","replyToPid":0}
发表于 2020-2-26 00:37:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"compressor bypassing a little oil in air. needs new cadesint filter.  normal issues. don't blame the whole truck. its usually p!ss poor drivers fault truck is junk.","replyToPid":0}
发表于 2020-2-26 10:20:00 来自手机 | 显示全部楼层
923301 发表于 2020-02-25 17:53:24 air compressor needs to be replaced.
","text":"shut up no one asked you \nlow life scumbagmotherfucker","replyToPid":332869}
发表于 2020-2-26 10:19:16 来自手机 | 显示全部楼层
926658 发表于 2020-02-25 16:37:49 compressor bypassing a little oil in air. needs new cadesint filter.  normal issues. don't blame the whole truck. its usually p!ss poor drivers fault truck is junk.
","text":"my A$$ leak's like that I'm captain k","replyToPid":332860}
发表于 2020-2-26 10:18:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"oil in my A$$ I'm captain k","replyToPid":0}
 楼主| 发表于 2020-2-27 03:30:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"hey if captain k has a problem with me stop running your fingers on tp and come see me im on my way to az and the Iowa i don't run logs ill meet you and slove your problem you have with me","replyToPid":0}
GMT+8, 2026-2-15 08:49 , Processed in 0.054847 second(s), 24 queries .
