查看: 1567|回复: 30
fuel island 30 min break takers
 楼主| 发表于 2020-2-25 21:47:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"what would you think about putting a high value security seal on a trailer for those lazy s.o.b.'s with a little card/note? I was thinking about a msg telling them this was applied while I waited for your lazy a$$ to move from the fuel island, since you wasted my time I'm now gonna waste yours. have a great day","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2220.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true,"externalShare":false}
发表于 2020-2-25 22:32:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"slash their tires","replyToPid":0}
回复 支持 4 反对 6
 楼主| 发表于 2020-2-26 00:29:48 来自手机 | 显示全部楼层
295387 发表于 2020-02-25 16:06:00 You do what you need to some take 30 min breaks some take and repair there trucks some sleep in fuel island it’s really a sad affair
","text":"all drivers have their responsibilities, but inconveniencing others because of laziness is not acceptable.","replyToPid":332851}
回复 支持 7 反对 1
发表于 2020-2-26 00:06:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"You do what you need to some take 30 min breaks some take and repair there trucks some sleep in fuel island it’s really a sad affair ","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-2-25 22:25:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not that it isn't a good idea my friend, but it would only take a bolt cutter to get it off, however depending where the inconsiderate driver was delivering to, it would definitely delay the driver some. Doubtful they'd get the hint without the note and it happening multiple times.","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-2-25 22:10:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"You need to put washers in both sides of the lock so only way to get off is flame cut or grinder","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-3-25 10:17:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"If I see ya taking a break on the fuel island I’ll pull your fifth wheel handle and let you enjoy the aftermath ","replyToPid":0}
回复 支持 2 反对 3
 楼主| 发表于 2020-2-25 22:04:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"security seals like that when purchased in bulk, pre tax and shipping costs, only $1.58 each. I need to shop around more but I'm liking the idea","replyToPid":0}
 楼主| 发表于 2020-2-25 22:18:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks for the knowledge 👍👍","replyToPid":0}
发表于 2020-2-25 21:58:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"An incendiary grenade to their engine will do much better","replyToPid":0}
发表于 2020-2-25 23:50:24 来自手机 | 显示全部楼层
900409 发表于 2020-02-25 15:14:13 My personal favourite. \n\nLoosen the valve core of a tire. Enough for a slow leak. \n\nOr duct tape over their lic plate
","text":"I was thinking of spray painting their lights with black paint...","replyToPid":332835}
 楼主| 发表于 2020-2-25 22:01:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'd definitely agree but dont want to bl.ow others up at the truck stop. Theres a lot of good drivers out there I'd hate for them to be part of the collateral damage.","replyToPid":0}
 楼主| 发表于 2020-2-25 22:02:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"in order for bl.ow to appear you have to add a . in there somewhere.  thanks t.p.","replyToPid":0}
 楼主| 发表于 2020-2-25 22:35:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's why I'd leave a note, plastic tag I was thinking","replyToPid":0}
GMT+8, 2026-4-17 19:54 , Processed in 0.119583 second(s), 24 queries .
