查看: 150|回复: 15
How many states have you been to?
 楼主| 发表于 2020-2-25 11:14:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"Professional travel to, or personal travel to?\n\nI been to all fifty state during my life time. Professional I have been to thirty state.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-25 12:12:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"(Better question would be how many drivers drove commercial OUTSIDE the US?) 🤔","replyToPid":0}
发表于 2020-2-26 07:28:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've driven the lower 48.. Alaska on the bucket list","replyToPid":0}
发表于 2020-2-26 07:55:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've driven to or thru 45 out of 48 states, and 4 Canadian provinces as a driver.  I've been to several countries including Mexico while in the service ","replyToPid":0}
 楼主| 发表于 2020-2-26 10:50:50 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I been to Mexico and Canada few times in my life but never commercially. Not sure if I can go to Canada driving a truck. Been told that if you have a dwi on your driving record that they won’t let you in. Not sure on how true that is or not. Its been almost thirty one years now. Never had a problem with going there on vacation."}
发表于 2020-2-26 11:23:55 来自手机 | 显示全部楼层
758476 发表于 2020-02-26 02:50:50 I been to Mexico and Canada few times in my life but never commercially. Not sure if I can go to Canada driving a truck. Been told that if you have a dwi on your driving record that they won’t let you in. Not sure on how true that is or not. Its been almost thirty one years now. Never had a problem with going there on vacation.
","text":"You should be fine commercially...I had a alcohol related driving issue that was over 25 years when I got a fast pass to allow me into Canada.","replyToPid":333155}
 楼主| 发表于 2020-2-26 11:49:48 来自手机 | 显示全部楼层
674254 发表于 2020-02-26 03:23:55 You should be fine commercially...I had a alcohol related driving issue that was over 25 years when I got a fast pass to allow me into Canada.
","text":"Okay thank you ","replyToPid":333186}
发表于 2020-2-26 11:55:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your company goes into Canada, check and see if they will get you a fast pass, otherwise you need a passport ","replyToPid":333202}
 楼主| 发表于 2020-2-26 12:27:57 来自手机 | 显示全部楼层
674254 发表于 2020-02-26 03:55:48 If your company goes into Canada, check and see if they will get you a fast pass, otherwise you need a passport
","text":"The company that I work for, as of right now does not go to Canada. Thank you for the advice I am sure someone will be able to use it.","replyToPid":333204}
发表于 2020-2-26 23:25:39 来自手机 | 显示全部楼层
674254 发表于 2020-02-25 23:55:13 I've driven to or thru 45 out of 48 states, and 4 Canadian provinces as a driver.  I've been to several countries including Mexico while in the service
","text":"No Middle East driving?","replyToPid":333097}
GMT+8, 2026-2-13 14:32 , Processed in 0.054406 second(s), 24 queries .
