查看: 183|回复: 7
I-80 Wyoming.
 楼主| 发表于 2020-2-25 04:53:41 来自手机 | 显示全部楼层 |阅读模式
{"text":"Shut down from Rock Springs to Laramie. Cops said won’t be open until tomorrow. Truck stops are filling up. Flying J truck stop off of exit 104 is already full but there’s some spots at the dirt lot next to it. Supposed to be 60-90 mile an hour winds through this area and Colorado too so get somewhere. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-2-25 06:09:41 来自手机 | 显示全部楼层
336899 发表于 2020-02-24 22:03:53 Is this an old post? nowhere on the Wyoming's. site does it say I80 closed at the moment.\nyes there's high winds and blowing snow but that's typical and high winds are only like 40 miles an hour. I'm looking at the live cams and there's trucks and cars going by. https://www.wyoroad.info/pls/Browse/WRR.RoutesResults?SelectedRoute=I80
","text":"Just opened back up. Not an old post. I was turned around and sent back to rock springs. ","replyToPid":332238}
发表于 2020-2-25 06:01:56 来自手机 | 显示全部楼层
625878 发表于 2020-02-24 21:52:43 They real need to plant trees on each side of the interstate, a lot of their problems would be solved
","text":"That would make common sense.  Let's see if a \ngovernment official would take that advice","replyToPid":332232}
发表于 2020-2-25 05:30:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe the Sweetwater Event Center is open...that's where I had to park last time it closed...unfortunately no amenities in the area ","replyToPid":0}
发表于 2020-2-25 06:06:59 来自手机 | 显示全部楼层
","text":"actually they have tried snow fences many decades ago and they definitely don't work because the snow gets between both sides of the interstate and piles up on the interstate. wind directions change often in Wyoming.","replyToPid":332232}
发表于 2020-2-25 06:09:16 来自手机 | 显示全部楼层
625878 发表于 2020-02-24 22:06:33 Well that is an oxymoron, you can’t have government and common sense in the same sentence.
","text":"You can, but it is always laughable or at least a punchline🤔","replyToPid":332241}
发表于 2020-2-25 06:03:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is this an old post? nowhere on the Wyoming's. site does it say I80 closed at the moment.\nyes there's high winds and blowing snow but that's typical and high winds are only like 40 miles an hour. I'm looking at the live cams and there's trucks and cars going by. https://www.wyoroad.info/pls/Browse/WRR.RoutesResults?SelectedRoute=I80","replyToPid":0}
发表于 2020-2-25 07:28:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"I believe everything is open up now but that could change trees will be a good idea but it’s not the best terrain for tree growth . I drove through Wyoming last night it was all good nobody was on the freeway through ","replyToPid":0}
GMT+8, 2026-2-15 10:34 , Processed in 0.083655 second(s), 24 queries .
