查看: 301|回复: 10
Truck Fridge
 楼主| 发表于 2020-2-24 03:07:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"Howdy everyone!! Hope all has been well. I am looking to finally purchase a fridge for my truck. If you have one, can you chime in with the brand of fridge & how long you've had it. Please and thank you!!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-24 03:31:35 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Go to Walmart and buy the Coleman brand. Plugs right into the cigarette lighter. It works great. "}
发表于 2020-2-24 08:48:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had a dorm fridge I bought at Walmart for $160. It still worked great after 2 years when I moved into a truck with a built-in fridge. Of course if you buy a dorm fridge, you're going to need space for it as well as an inverter or APU to power it.","replyToPid":0}
发表于 2020-3-20 20:55:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"If money isn't a factor, you should check out Truck Fridge. They make OEM replacements for most truck and RV Makes, Models, and years. I got mine for a 18 Peterbilt 579, it's been working perfectly since May of last year. Also, the inner workings are specifically designed to withstand the bumping, shaking, and wild temp fluctuations that are inherent in the environment. They sell the mounting brackets and wiring harness (for converting a 12v plug into a DC connection,  much safer) specific to your truck and fridge also. I highly recommend getting your fridge from them, but come prepared to spend around $500. My company paid for mine, just fyi.\n\nwww.truckfridge.com\n\n(502) 863-4536\n\n100 Triport Cir, Georgetown, KY 40324\n\nI-75 exit 129\nYou can park at the Pilot next door and walk in to look at floor models and ask all the questions you need to ask. Super convenient!","replyToPid":0}
发表于 2020-3-21 03:17:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"1.7 cubic hisense fridge from Walmart best option it’s like 89$","replyToPid":0}
发表于 2020-2-25 20:42:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Haier with two doors, freezer compartment top, fridge bottom.","replyToPid":0}
发表于 2020-2-25 00:12:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have truckfridge. have to keep it at lowest setting or everything freezes. I'm sure if I set it higher I can use the whole fridge as a freezer.","replyToPid":0}
发表于 2020-2-24 04:15:54 来自手机 | 显示全部楼层
495099 发表于 2020-02-23 19:31:35 Go to Walmart and buy the Coleman brand. Plugs right into the cigarette lighter. It works great.
","text":"Yep. I’ve had this Coleman for about a year. Overpaid from Loves, but yes, Walmart has the same. Runs good. I unplug for a few hours every few nights bc I read it’s not good to run them non stop without a little defrosting of the fan area. \n\nComments / reviews online say the older fan blades were metal and a better quality. \n\nNot sure about that, \nMine still runs good though. ","replyToPid":331522}
发表于 2020-2-24 03:56:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a fridge from truckfridge.com (3 months old)  and a whynter 84qt chest freezer (2 years old)..","replyToPid":0}
发表于 2020-2-24 03:14:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends on the amount of room you have.  I suggest a college dorm fridge/freezer. Those will actually cool things down. Most truck fridges are just cold plates that maintain temp.","replyToPid":0}
 楼主| 发表于 2020-3-3 02:57:39 来自手机 | 显示全部楼层
863508 发表于 2020-02-25 12:42:11 Haier with two doors, freezer compartment top, fridge bottom.
","text":"Thanks. I like this one with the 2 compartments.","replyToPid":332780}
GMT+8, 2026-4-18 08:05 , Processed in 0.159447 second(s), 24 queries .
