查看: 185|回复: 8
ABOUT ELD
 楼主| 发表于 2020-2-23 22:03:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"Dear friends give your reviews and suggestions about ELD, specially when you have very little distance from your family and your ELD no more....","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-24 09:49:30 来自手机 | 显示全部楼层
336899 发表于 2020-02-23 21:58:12 legally you can't PC home if you're out of your 14 hours even if your home is your terminal or not.\nBut... 😉😉
","text":"Personal conveyance and take the penalty if the want to write you up. Be with your family if you’re that close and to h*ll with the rules","replyToPid":331609}
发表于 2020-2-24 17:21:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's not a just a penalty you can lose your CDL eventually. \nFalsifying records is a 7 pointer against your CSA SMS. \nSome violations of the ELD bring fines  between $1000 and $10,000 each violation. May put you 10 hours out of service. Cost you a tow,  ETC...","replyToPid":0}
发表于 2020-2-23 23:24:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"PC home & sign out","replyToPid":0}
发表于 2020-2-24 05:58:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"legally you can't PC home if you're out of your 14 hours even if your home is your terminal or not.\nBut... 😉😉","replyToPid":0}
发表于 2020-2-24 10:48:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Which is why we have ELDs in the first place.","replyToPid":0}
发表于 2020-2-24 17:06:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes that's part of the reason","replyToPid":0}
 楼主| 发表于 2020-3-10 08:44:43 来自手机 | 显示全部楼层
336899 发表于 2020-02-24 09:21:13 It's not a just a penalty you can lose your CDL eventually. \nFalsifying records is a 7 pointer against your CSA SMS. \nSome violations of the ELD bring fines  between $1000 and $10,000 each violation. May put you 10 hours out of service. Cost you a tow,  ETC...
","text":"Finally too tuff job for truckers even all the time life on risk after that ELD hard rules...if you want to spend more time with your family drive local on paper log book, I think is good way,","replyToPid":331985}
 楼主| 发表于 2020-3-10 08:48:06 来自手机 | 显示全部楼层
255377 发表于 2020-02-24 01:49:30 Personal conveyance and take the penalty if the want to write you up. Be with your family if you’re that close and to h*ll with the rules
","text":"Same emotions here bro","replyToPid":331749}
GMT+8, 2026-4-18 02:52 , Processed in 0.085531 second(s), 24 queries .
