查看: 304|回复: 45
help!
 楼主| 发表于 2020-2-22 01:57:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"does anyone know the process to find out if a truck has been wrecked, if you arent sure who the owner was to the previous owner. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-22 03:13:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.rigdig.com/","replyToPid":0}
发表于 2020-2-22 02:29:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can get car fax report for trucks","replyToPid":0}
发表于 2020-2-22 15:28:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why are you wondering if it was wrecked? Is it chewing up tires too fast?","replyToPid":0}
发表于 2020-2-22 18:59:34 来自手机 | 显示全部楼层
674254 发表于 2020-02-21 22:13:06 I'd offer...but I think he called dibs on ya...🤣🤣🤣
","text":"brother I'm not in the race. I'm just passing the time","replyToPid":330461}
发表于 2020-2-22 19:07:27 来自手机 | 显示全部楼层
255377 发表于 2020-02-22 07:35:44 TT checked under ya, how I know is because he asked me to scoot over 😜
","text":"🤠👉👌","replyToPid":330760}
发表于 2020-2-22 19:06:08 来自手机 | 显示全部楼层
255377 发表于 2020-02-22 06:52:38 I’d get an oil sample and have an ase certified mechanic inspect it. If you’re financing it should be about 10% on used commercial equipment. You’ll have a depreciation tax advantage. You’ll want to save about 10 cpm for maintenance. Always run full synthetic everything you can. Extended life coolant and run your overhead every year. Good luck and I have more advice if you want it 😃
","text":"I'll check her oil. I'm certified,  have a mechanic shirt and all.👌🤣🤣🛢🛠","replyToPid":330603}
发表于 2020-2-22 07:31:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rig dig","replyToPid":0}
发表于 2020-2-22 06:13:06 来自手机 | 显示全部楼层
674254 发表于 2020-02-21 22:06:26 He would too...🤣🤣🤣
","text":"I'd offer...but I think he called dibs on ya...🤣🤣🤣","replyToPid":330460}
发表于 2020-2-22 02:01:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"the truck accident is not that bad as long as the frame is straight. look at the frame and check out if it's not bent or crooked. anything else is easy to replace","replyToPid":0}
 楼主| 发表于 2020-2-22 04:24:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"😔😔","replyToPid":330402}
 楼主| 发表于 2020-2-22 02:02:51 来自手机 | 显示全部楼层
84882 发表于 2020-02-21 18:01:14 the truck accident is not that bad as long as the frame is straight. look at the frame and check out if it's not bent or crooked. anything else is easy to replace
","text":"that's the problem. tried to have the windshield replaced and the guy said looked to him like it had been laid over.  had to shave the windshield to get it in place.","replyToPid":330355}
 楼主| 发表于 2020-2-22 02:31:03 来自手机 | 显示全部楼层
484866 发表于 2020-02-21 18:29:35 You can get car fax report for trucks
","text":"thanks. wasn't sure if it worked like that.","replyToPid":330360}
发表于 2020-2-22 04:00:32 来自手机 | 显示全部楼层
","text":"only if it was reported","replyToPid":330360}
 楼主| 发表于 2020-2-22 04:01:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks!","replyToPid":0}
发表于 2020-2-22 05:09:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm sure that TT will check under ya🤣🤣🤣","replyToPid":330410}
GMT+8, 2026-2-13 12:49 , Processed in 0.102055 second(s), 24 queries .
