查看: 215|回复: 6
Cb radio questions
 楼主| 发表于 2020-2-21 02:25:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"I am not sure where to put this question but I was wondering if there is an antenna that you recommend and what length it should be?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-21 02:48:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've had more wives in 40 years, than I have Wilson 2000 antennas. I recommend them...the antennas!","replyToPid":0}
发表于 2020-2-21 04:25:05 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"A pro CB tech once told me not to waste money on a Fire Stick, just buy a cheap antennae as long as it’s shielded to help fight  feedback interference, and and cut about a quarter length off it and place a plastic cap on the end. If you get a lot of feedback, then install a ground loop. "}
发表于 2020-2-21 02:35:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depend what kind of truck you have,, but some truck comes with built in antenna factory manufactured,, and it don’t matter what length they are,, it’s normal length what they selling for trucks,, small ones are for cars ","replyToPid":0}
 楼主| 发表于 2020-2-21 11:40:14 来自手机 | 显示全部楼层
630066 发表于 2020-02-20 18:35:58 Depend what kind of truck you have,, but some truck comes with built in antenna factory manufactured,, and it don’t matter what length they are,, it’s normal length what they selling for trucks,, small ones are for cars
","text":"My truck has a built-in antenna but I heard it wasn’t very good I have a 2017 freightliner Cascadia","replyToPid":328994}
 楼主| 发表于 2020-2-21 11:55:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is ssb worth getting as a feature?","replyToPid":0}
发表于 2020-2-25 10:40:34 来自手机 | 显示全部楼层
722301 发表于 2020-02-21 03:40:14 My truck has a built-in antenna but I heard it wasn’t very good I have a 2017 freightliner Cascadia
","text":"I also have built in antenna, and is cascadia 2020, works perfect ","replyToPid":329347}
GMT+8, 2026-4-17 03:05 , Processed in 0.563634 second(s), 24 queries .
