查看: 99|回复: 3
Dispatch
 楼主| 发表于 2020-2-21 00:54:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"Company , lease, oo, key is we get loads from dispatch, broker, account, ect... If you're getting the loads you need/want, try remembering that in financial and or down times. Those same people or person that got you those loads will make sure you recoup your loss in one form or another. This is what I've found based on my work performance as well as accepting loads in area's most won't transport within U. S. borders. I'm not a company driver but I've applied the same mindset when I was and got the results I needed/looking for. Keep your head up, continue accomplishing/setting new goals, and above all be safe having fun along the way. \n\n\n(Not an experienced driver, learning to be experienced while enjoying what I do daily)\n\n\n-Safe travels \n","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-21 06:09:09 来自手机 | 显示全部楼层
674254 发表于 2020-02-20 18:55:38 Well said my friend...my outlook is the same
","text":"Copy that","replyToPid":328999}
发表于 2020-2-21 02:55:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well said my friend...my outlook is the same ","replyToPid":0}
 楼主| 发表于 2020-2-21 10:53:12 来自手机 | 显示全部楼层
","text":"10/4","replyToPid":328999}
GMT+8, 2026-2-15 12:00 , Processed in 1.316307 second(s), 24 queries .
