查看: 213|回复: 15
Good morning ☕️ from just north of Tremonton, UT
 楼主| 发表于 2020-2-21 00:10:41 来自手机 | 显示全部楼层 |阅读模式
{"text":"Rolling for Washington state ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1102.0,\"name\":\"\",\"url\":\"\",\"width\":826.0}]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-2-21 02:11:50 来自手机 | 显示全部楼层
924223 发表于 2020-02-20 17:10:36 yoúr däd îs ã pëdö
","text":"Go back to your hole little troll.  I know that you are just an ignorant, racist, bored little life form who just wants to get a rise for laughs. It's not going to work.  So, go back and have fun playing by yourself.","replyToPid":328960}
发表于 2020-2-21 01:11:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"your dad fûçks little boys in the áss","replyToPid":0}
发表于 2020-2-21 01:10:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"yoúr däd îs ã pëdö","replyToPid":0}
 楼主| 发表于 2020-2-21 03:54:27 来自手机 | 显示全部楼层
575570 发表于 2020-02-20 19:52:30 Good morning enjoy your day☕️
","text":"You too sir","replyToPid":329019}
发表于 2020-2-21 00:43:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s a nice view! ","replyToPid":0}
发表于 2020-2-21 00:39:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"You'll be in good weather all weekend on that end of the map. Safe travels","replyToPid":0}
 楼主| 发表于 2020-2-21 00:23:24 来自手机 | 显示全部楼层
256271 发表于 2020-02-20 16:19:31 Already in Washington State and it's 36 degrees up here Today
","text":"A heat wave 🤣","replyToPid":328935}
发表于 2020-2-21 00:19:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Already in Washington State and it's 36 degrees up here Today","replyToPid":0}
 楼主| 发表于 2020-2-21 01:15:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"All I need now is warmer temps 🤣","replyToPid":328944}
 楼主| 发表于 2020-2-21 01:16:02 来自手机 | 显示全部楼层
435615 发表于 2020-02-20 16:39:20 You'll be in good weather all weekend on that end of the map. Safe travels
","text":"Sounds good...same with you ","replyToPid":328941}
发表于 2020-2-21 01:54:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"(Such a lonely highway you're on?) 🤔","replyToPid":0}
GMT+8, 2026-4-18 13:23 , Processed in 0.078598 second(s), 24 queries .
