查看: 198|回复: 11
swift hiding in the lot peeking over a rock
 楼主| 发表于 2020-2-20 13:12:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1405.0,\"name\":\"\",\"url\":\"\",\"width\":1440.0}]","canComment":true,"externalShare":false}
发表于 2020-2-21 11:59:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's a picture; it doesn't record movement. You're so stùpid lol..","replyToPid":0}
发表于 2020-2-21 12:00:16 来自手机 | 显示全部楼层
923301 发表于 2020-02-21 03:15:54 Who in tf actually gives a Kenworth to a Swift driver anyway??
","text":"It's a lease, jack-åss.","replyToPid":329315}
发表于 2020-2-21 10:17:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nothing stops a Kenworth...","replyToPid":0}
回复 支持 0 反对 3
发表于 2020-2-21 06:22:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s only rock n roll but I like it, like it, yes I dooo","replyToPid":0}
发表于 2020-2-21 12:15:29 来自手机 | 显示全部楼层
923301 发表于 2020-02-21 04:07:54 Still a jask@$$ swift driver....jack@$$.
","text":"You're not even clever.. I've grown bored of you.. moving on...","replyToPid":329355}
发表于 2020-2-21 12:12:01 来自手机 | 显示全部楼层
923301 发表于 2020-02-21 04:09:03 You're not too intelligent,  are you? What does the recording of movement have to do with anything?
","text":"seriously? lol wow... I'll explain like you're two.. if the truck is still moving, you'd need something called video to see it, not a still frame.","replyToPid":329357}
发表于 2020-2-20 23:06:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Africa","replyToPid":0}
发表于 2020-2-21 03:45:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Clearly, he forgot to pay attention to his surroundings ","replyToPid":0}
发表于 2020-2-20 13:24:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"There’s costly mistake probably wreck the motor","replyToPid":0}
发表于 2020-2-20 19:07:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Belly scratcher","replyToPid":0}
发表于 2020-2-20 21:51:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Doing oil change ","replyToPid":0}
GMT+8, 2026-2-13 17:42 , Processed in 0.123658 second(s), 24 queries .
