查看: 129|回复: 10
paper logs or eld??
 楼主| 发表于 2020-2-20 11:54:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"paper logs are so much better","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-2-21 04:05:41 来自手机 | 显示全部楼层
670777 发表于 2020-02-20 14:35:09 Why are paper logs better?
","text":"You can stop when you want and don’t have to worry about the clock is ticking all the time ","replyToPid":328857}
发表于 2020-2-20 13:06:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Paper logs","replyToPid":0}
发表于 2020-2-20 18:46:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Paper logs. Less stressful.","replyToPid":0}
发表于 2020-2-20 19:38:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Eld are for women ","replyToPid":0}
发表于 2020-2-20 12:20:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"paper logs  📝","replyToPid":0}
发表于 2020-2-20 22:35:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why are paper logs better?","replyToPid":0}
 楼主| 发表于 2020-2-21 07:39:43 来自手机 | 显示全部楼层
688983 发表于 2020-02-20 21:16:31 Because you can lie change your duty status and go the extra miles when stuck in traffic
","text":"i never knew you could do this i thought when you started driving your paper logs clicked on and your time started😂","replyToPid":329047}
 楼主| 发表于 2020-2-21 07:42:56 来自手机 | 显示全部楼层
295387 发表于 2020-02-20 20:05:41 You can stop when you want and don’t have to worry about the clock is ticking all the time
","text":"im not saying ive done this but if you to get 1200 miles in one shift  paper logs are the way to go worry about fixing it later","replyToPid":329026}
发表于 2020-2-21 07:52:13 来自手机 | 显示全部楼层
885600 发表于 2020-02-20 23:42:56 im not saying ive done this but if you to get 1200 miles in one shift  paper logs are the way to go worry about fixing it later
","text":"👍","replyToPid":329170}
GMT+8, 2026-2-13 17:43 , Processed in 0.066839 second(s), 24 queries .
