查看: 165|回复: 8
2018 Peterbilt 579 warning light. Antifreeze is topped up still this warning not going away. what this could be?
 楼主| 发表于 2020-2-17 00:44:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[{\"url\":\"http://d2w8udw005hdju.cloudfront.net/video/171725/android_11398_1581871117329.mp4\"}]","link":"{}","pics":"[{\"description\":\"\",\"height\":607.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true,"externalShare":false}
发表于 2020-2-20 02:09:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bad low coolant sensor in the bottom of your coolant tank","replyToPid":0}
 楼主| 发表于 2020-2-20 13:14:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes they replaced the tank costing me around $1200","replyToPid":0}
 楼主| 发表于 2020-2-20 13:16:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't understand why they put little wobbly sensor inside the tank","replyToPid":0}
发表于 2020-2-22 15:37:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Where was this?! -3 at 12:00pm!","replyToPid":0}
 楼主| 发表于 2020-2-22 20:25:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"lol. its northern michigan last week","replyToPid":0}
发表于 2020-2-23 11:51:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s the pedophile sensor ","replyToPid":0}
 楼主| 发表于 2020-2-23 21:11:30 来自手机 | 显示全部楼层
925326 发表于 2020-02-23 03:51:33 It’s the pedophile sensor
","text":"You grew up with whoress? Happy mother day to your mother","replyToPid":331184}
发表于 2020-6-11 01:31:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pop out the coolant sensor cross a paper clip from one entry to the other should stop that code watch your temperature tho till u get to your shop","replyToPid":0}
GMT+8, 2026-4-17 14:26 , Processed in 0.114183 second(s), 24 queries .
