查看: 226|回复: 13
trucker bbq
 楼主| 发表于 2020-2-16 05:20:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"I highly recommend this in your truck","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true,"externalShare":false}
发表于 2020-2-16 06:43:25 来自手机 | 显示全部楼层
649124 发表于 2020-02-15 22:30:14 Idk...anything open flame...inside a truck?🤔
","text":"I only use mine outside...don't need to cook the truck 🤣","replyToPid":326588}
发表于 2020-2-16 06:30:14 来自手机 | 显示全部楼层
发表于 2020-2-16 08:54:03 来自手机 | 显示全部楼层
745349 发表于 2020-02-16 00:27:30 after a lengthy search I found a Whirlpool 0.5 ft³ microwave that will fit in one of the shelf pockets of my truck. The opening is only 16 in wide and I have not been able to find a microwave less than 16 in to put in there until now
","text":"I'm looking at the 700 watt Mike at Walmart, figured that it would work ","replyToPid":326644}
发表于 2020-2-16 08:27:30 来自手机 | 显示全部楼层
674254 发表于 2020-02-15 21:55:07 All I need now is a microwave...hopefully I will be getting that next week 🤞
","text":"after a lengthy search I found a Whirlpool 0.5 ft³ microwave that will fit in one of the shelf pockets of my truck. The opening is only 16 in wide and I have not been able to find a microwave less than 16 in to put in there until now","replyToPid":326531}
发表于 2020-2-16 07:25:45 来自手机 | 显示全部楼层
发表于 2020-2-16 05:53:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Got portable one...just need to clean it 🤣","replyToPid":0}
发表于 2020-2-16 06:02:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"sweet","replyToPid":0}
发表于 2020-2-16 09:36:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤩 ","replyToPid":0}
发表于 2020-2-16 06:49:59 来自手机 | 显示全部楼层
","text":"Make it look like some of the FedEx trucks I've seen","replyToPid":326588}
发表于 2020-2-16 05:55:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"All I need now is a microwave...hopefully I will be getting that next week 🤞","replyToPid":0}
发表于 2020-2-16 06:51:08 来自手机 | 显示全部楼层
907952 发表于 2020-02-15 22:49:59 Make it look like some of the FedEx trucks I've seen
","text":"🤣🤣🤣","replyToPid":326597}
 楼主| 发表于 2020-2-16 07:08:41 来自手机 | 显示全部楼层
","text":"alternative heat source if engine quits","replyToPid":326588}
 楼主| 发表于 2020-2-16 07:12:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"lol","replyToPid":326599}
GMT+8, 2026-2-13 20:52 , Processed in 0.786802 second(s), 24 queries .
