查看: 996|回复: 28
legal or illegal?
 楼主| 发表于 2020-2-13 11:03:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"run it or turn it back ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2064.0,\"name\":\"\",\"url\":\"\",\"width\":1548.0},{\"description\":\"\",\"height\":1548.0,\"name\":\"\",\"url\":\"\",\"width\":2064.0}]","canComment":true,"externalShare":false}
发表于 2020-2-13 14:19:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"slide the tandems one hole but if you gotta ask. go back to trucking school. or just get out of the trucking industry","replyToPid":0}
回复 支持 7 反对 4
发表于 2020-2-13 12:37:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends on where you were born and if you have a green card or Visa","replyToPid":0}
回复 支持 7 反对 2
发表于 2020-2-13 11:25:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your just fine ","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-2-13 23:18:18 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Get on c.b. and ask if there are chase cars at the scales and just run the scales! Or go around the scales!"}
回复 支持 5 反对 1
发表于 2020-2-13 23:43:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Slide tandems or take it back. A ticket and points on your CSA is not worth it.","replyToPid":0}
回复 支持 2 反对 3
发表于 2020-2-13 23:40:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"run it, the miles feel better riding dirty","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-2-13 12:01:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Or move the 5th wheel one hole","replyToPid":0}
发表于 2020-2-13 11:26:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"As a driver you should know. \n\nI run Canadian so my rules are a bit different. ","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-2-13 23:43:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"but honestly if your 5th wheel slides you can move it forward a notch and","replyToPid":0}
发表于 2020-2-13 11:50:23 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I would run it. most states only worry about gross over 80k. also I'm certain there is a 1% of total gross allowed over on tandems.."}
发表于 2020-2-13 11:29:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"you will get ticket for that 80lbs over","replyToPid":0}
回复 支持 2 反对 2
发表于 2020-2-13 11:54:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"technically illegal,  but in 22 yrs I've never had a ticket over 80 lbd....even 200","replyToPid":0}
发表于 2020-2-13 14:41:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"(Need more details about where the trailer tandems are set.) 🤔","replyToPid":0}
GMT+8, 2026-4-17 08:58 , Processed in 0.121218 second(s), 24 queries .
